Old 07-09-2022, 01:13 AM   #41
KULTULZ
KULTULZ's Avatar
Arrow Re: Brakes - Wives Tales & Misconceptions
- 1300HP MERC COMET BRAKE FAILURE -
https://www.reddit.com/r/cars/commen...brake_failure/
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-13-2022, 09:22 AM   #42
KULTULZ
KULTULZ's Avatar
Question Re: Brakes - Wives Tales & Misconceptions
- WHILE CAROUSING WITH MY BROWSER -
To Wit - Question Asking If An External PRV Is Needed ...
You have a choice. The idea is to keep your rear shoes adjusted close to the drums. Two methods prevail, self-adjusters or residual valves.
Now we get to 'personal preference'...
When self adjusters work as they should, nothing is better because they actually turn the star wheel which expands the shoes.
Residual valves simply prevent the shoes from retracting by keeping ten psi on the hydraulic line. That means the pistons keep extending, and extending as the shoes wear. Eventually, a piston may pop right out of the bore. Yes, I've seen it happen. That leaves the rear brake circuit inoperable (with a soaking mess of brake fluid inside one drum).
11" self adjuster kits are very inexpensive and available at just about all auto parts stores. That is what I use.
Now this is on a respected FORD RELATED FORUM.
People, I am getting scared.
- WHY IS IT ... -
Old 07-13-2022, 03:30 PM   #43
rich b
rich b's Avatar
Default Re: Brakes - Wives Tales & Misconceptions
Worst part, people believe these "experts" and turn this misinformation into facts as it is repeated.
rich b is offline   Reply With Quote
Old 07-20-2022, 03:09 AM   #44
KULTULZ
KULTULZ's Avatar
Exclamation Re: Brakes - Wives Tales & Misconceptions
- WHAT'S WRONG WITH THIS PICTURE -
- WHY IS IT ... -
Old 07-20-2022, 08:44 AM   #45
KULTULZ
KULTULZ's Avatar
The below from a website discussing the GRANADA SWAP (FRT) -
When you're getting the spindle assemblies at the Salvage Yard, don't forget the distribution block. Most any post-1970 Ford distribution block for dual circuit braking systems will work.
The unit has a pressure sensing diaphragm which, when detecting a pressure drop, will close off fluid flow to the dropped circuit. This will allow you to still have either front or back brakes. Take the connector and a partial strand of the wiring, as you may wish to hook up a "Brake Warning" light later.
A diaphragm? It is a pintle (and it will not block cross-flow).
I think the writer is describing the PDV (PRESSURE DIFFERENTIAL VALVE) as FORD did not actually release a COMBINATION VALVE (an assembly consisting of two or more individual braking valves) until 1972. PDV, PPV and METERING were separate.
As for the PDV, if one does not want or need the WARNING LAMP FEATURE, actual DISTRIBUTION BLOCKS are available for a neater appearance.
While this particular tech write-up has a 2001 date, it is still online and should have been corrected (IMO of course).
- WHY IS IT ... -
Old 07-21-2022, 06:33 AM   #46
ms fowler
I have a friend who lives in AMC world. He constantly complains about these ne "experts" and the false information they confidently spew. I thought that maybe those people were somehow all attracted to AMC vehicles. Alas--I see they have infected FoMoCo world too.
ms fowler is offline   Reply With Quote
Old 07-21-2022, 08:00 AM   #47
KULTULZ
KULTULZ's Avatar
Cool Re: Brakes - Wives Tales & Misconceptions
No ma'am, it is hobby wide and industry wide. I have seen some things you wouldn't believe.
- WHY IS IT ... -
Old 07-31-2022, 02:14 AM   #48
KULTULZ
KULTULZ's Avatar
Follow-up video to MERC incident -
https://www.youtube.com/watch?v=Z-FqKRHnEBE
- WHY IS IT ... -
Old 08-10-2022, 04:13 AM   #49
KULTULZ
KULTULZ's Avatar
Post Re: Brakes - Wives Tales & Misconceptions
- BRAKE PROPORTIONING VALVES -
1. If you have the deeply-rooted need to install your own adjustable proportioning valve, be advised that they should NEVER be installed if the factory unit is still in place.
Proportioning valves in series with one another can do nasty, unpredictable things!
2. If you have the deeply-rooted need to install your own adjustable proportioning valve, be advised that they should NEVER be installed in-line to the front brakes. The effect would be to make your vehicle rear-biased before you could say “terminal over-steer.” Front brake line pressure should always be left alone – only the rear pressures should be considered for proportioning.
3. In all cases, the basic brake system balance needs to be close to optimized to start with. This is the only way that a proportioning valve can be effectively utilized. You should never assume that simply adding a proportioning valve will address all rear-bias conditions, as even the best proportioning valves must be well-matched to the target vehicle.
SOURCE - BRAKING VALVE THEORY - CENTRIC BRAKES
- https://centricparts.com/getmedia/d9...ing-valves.pdf
- WHY IS IT ... -
Old 08-10-2022, 06:21 AM   #50
Patrick brophy
They have good taste in hand tools. Knipex tools are top shelve.
Patrick brophy is offline   Reply With Quote
Old 08-10-2022, 11:50 AM   #51
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Brakes - Wives Tales & Misconceptions
You're correct there.
BUT, after scarring the hell out of the piston, won't he be surprised when the other one pops out ...
- WHY IS IT ... -
Old 08-10-2022, 10:04 PM   #52
miker98038
miker98038's Avatar
I worked with a really good construction superintendent for years. The tool/caliper reminds me of his old line.
“When all you’ve got is a hammer, everything looks like a nail”
When all you’ve got is water pumps……..
miker98038 is offline   Reply With Quote
Old 08-11-2022, 06:22 AM   #53
KULTULZ
KULTULZ's Avatar
And what are the odds he didn't open the caliper bleed screws and allowed the old fluid to go back into the ABS PUMP?
- WHY IS IT ... -
Old 08-11-2022, 06:55 AM   #54
KULTULZ
KULTULZ's Avatar
If you think that was salty, watch this procedure. He begins @ 5 seconds on the video -
https://www.youtube.com/watch?v=wSqDP-pwj2s
Now I don't know but this seems a little gnarly for me. On my personal ESCAPE, the pistons had to be rotated LH so a SPECIAL SERVICE TOOL was needed. I finally found the required adapter @ FORD of EUROPE and yes, it came from JOLLY 'OL ...
That piston is on a ratchet. You mess that ratchet up (don't even mind gnarling the piston or cutting the dust boot) and there is no self-adj feature. You then have to buy a new caliper or have in your tool box specialty tools to rebuild the caliper and also purchase service parts ($$$).
I used to see things like this on a daily basis. This is why I am so CDO (OCD in correct alphabetical order).
- WHY IS IT ... -
Old 08-11-2022, 06:44 PM   #55
KULTULZ
KULTULZ's Avatar
It seems the BFH and HOT WRENCH are the go to instead of a specialty tool.
And if a BFH (big f*cking hammer) doesn't work, go out to the shed and find the sledge ...
(Yes, I am retaining water this evening)
- WHY IS IT ... -
Old 08-11-2022, 07:53 PM   #56
KULTULZ
KULTULZ's Avatar
If you have the time (and have the interest), watch this video describing a COMBINATION VALVE and see if anything described is wrong (if anything is wrong) -
https://www.youtube.com/watch?v=g63mP4HwVEQ
- WHY IS IT ... -
Old 09-02-2022, 02:38 AM   #57
KULTULZ
KULTULZ's Avatar
OK, there seems to be little interest but over 3500 hits.
Here is another discussion that should make you sit up straight -
https://57fordsforever.com/smf/index.php?topic=9149.0
- WHY IS IT ... -
Old 09-03-2022, 04:38 AM   #58
KULTULZ
KULTULZ's Avatar
Another discussion concerning the need for a correctly adjusted MC push-rod -
https://www.jalopyjournal.com/forum/...issue.1272098/
- WHY IS IT ... -
Old 09-03-2022, 06:37 PM   #59
5851a
I don't have more than a basic caveman education on brakes. I will only work on my own. I will not work on anyone else's brakes period. From an 81-shop manual they have a slope chart covering all the fox platform cars for the combination valve. Since all of the cars use the same brakes with exception of the wagons. Seems though they concentrated on the amount of weight of the rear of the car. Some of the cars used different size rear wheel cylinders. 1/16th diameter difference does matter. Some of the cars used a different combination valve. My 95 truck and 91 Escort wagon had a brake valve hooked to rear suspension. I assumed it was a load sensing valve to hold off brakes empty and apply more pressure when loaded. When you start messing with brakes it takes a lot of experimentation. Dual master cylinders and hydro boost are not the end all cure all. Brakes are a science; I didn't do great in science. Figured Ford's glass house had lot more smarts and time than me. Yes, there is no emergency brake, always referred it to a parking brake in manuals.
5851a is offline   Reply With Quote
Old 09-04-2022, 04:24 AM   #60
KULTULZ
KULTULZ's Avatar
Talking Re: Brakes - Wives Tales & Misconceptions
Originally Posted by 5851a View Post
... there is no emergency brake, always referred it to a parking brake in manuals.
BOOTLEGGER'S TURN - https://www.wikimotors.org/what-is-a...ggers-turn.htm
- WHY IS IT ... -
