12-14-2015, 01:44 AM | #1 |
Delco distributor cam lube
Anybody know where a tube of this may be purchased? Thanks - Michael!
AC Delco U1901 Distributor Cam Lubricant Lube GM |
12-14-2015, 02:40 AM | #2 |
Re: Delco distributor cam lube
Standard Ignition makes some that is almost the same. I have a tube of the GM stuff
I bought at my first mechanics job. That was in 1966. My boss at the time gave me a hard time for buying such a large tube. He said it would last me the rest of my life with electronic ignition on the horizon. He was right. I still have that tube and it has 3/4 of a tube left in it. If you can't find any, I'll send you a squirt of it...... |
12-14-2015, 02:45 AM | #3 |
May I ask why so specific on the lube?
12-14-2015, 02:48 AM | #4 |
There are a few on ebay right now also.....
12-14-2015, 06:32 AM | #5 |
I have the standard ignition lube that Dodge mentioned. It is readily available at my shops jobber. One small tube will last forever. haah..
The model A suppliers sell dist cam lube also... Brattons part # 17490 Last edited by Mitch//pa; 12-14-2015 at 07:25 AM. |
12-14-2015, 10:40 AM | #6 |
Bill W.
12-14-2015, 10:51 AM | #7 |
I remember those points with the pads... They were usually the higher end ones
12-14-2015, 11:10 AM | #8 |
LUCAS points used to have SOLID TUNGSTEN contacts & lasted well, even the rubbing block lasted well, with GOOD lube.
Bill W.
12-14-2015, 11:23 AM | #9 | |
past 40+ years with great results. This is on distributors and mag's..and I'm on the same tube. http://www.ebay.com/itm/Distributor-...-/111635597757 |
12-14-2015, 11:23 AM | #10 |
We can get cam lube here at the parts stores, my have to wait for it, but, they can get it.
I too remember points with the felt strip. What do I know, I squirt them with oil. But, points didn't move [ wear] like they seem to today. |
12-14-2015, 11:31 AM | #11 | |
http://carkart.com/acdelco-ac-delco-...-CA11A1PFRY6OR Bob |
12-14-2015, 11:41 AM | #12 |
Look on the counter of your favorite parts store, Advanced Auto in this case. A little disposable tube is about a buck.
12-14-2015, 12:56 PM | #13 |
Like Dodge above, I bought mine when I was in my late teens. My dad worked for a automotive parts jobber and thats what he brought home. Got a big tube and still have lots left. Will last a couple life times.
12-14-2015, 01:14 PM | #14 |
12-14-2015, 01:19 PM | #15 | |
12-14-2015, 06:32 PM | #16 |
I asked at Carquest the other day, and the counter guy ended up going in the back and robbing the lube capsule from a set of points. Nice for me, but I bet whoever buys those points will be unhappy!
12-14-2015, 06:38 PM | #17 |
I find that many points now a days don't even come with that pill capsule... Can't remember the last time it did atleast with the standard brand
12-14-2015, 08:45 PM | #18 | |
I'm still on the same small tube I bought in the early 70's. |
12-14-2015, 09:21 PM | #19 |
Try your GM car Dealer Parts Department
12-14-2015, 09:31 PM | #20 |
