Old 03-26-2013, 12:07 PM   #1
Peter J
Peter J's Avatar
Default Quick question
Nothing really similar in search but I adjusted my pressure plate prior to installing my engine. Seemed like I had to turn in the adjustment screws a bunch. After installation, I've got a slipping clutch that I didn't have before the engine etc. was removed. Clutch disk is almost new and pressure plate is in good shape also. My question is: Could my adjustment be causing the clutch to slip? I have about 1.5" of clutch play before it engages and about 1/4" between the throwout bearing and the forks.
Thanks as always for your comments,
Pete
Peter J is offline   Reply With Quote
Old 03-26-2013, 01:37 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Quick question
Did you have the disc and PP bolted to the flywheel when you adjusted the 6 fingers?
Did you adjust them to 5/8" to 11/16"?
Old 03-26-2013, 03:47 PM   #3
Peter J
Peter J's Avatar
Tom,
Yes to both. I was just wondering if I goofed on the measurements (too far in) , it would be like riding the clutch making it slip.
Pete
Old 03-26-2013, 05:02 PM   #4
Tom Wesenberg
Pete
By forks I assume you mean the 6 fingers you adjusted.
The fork coming up from the shaft should stay against the collar and the bearing riding on the collar should remain a short distance from the 6 fingers when the pedal is released. Can you remove the hand hole cover and take a picture of the bearing and 6 fingers? I can't imagine what is wrong to allow slipage, unless the disc is in backwards, but I doubt you did that.
Old 03-26-2013, 06:04 PM   #5
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
The clutch pedal should only have about 1/2" free play at the top. 1 1/2" of free play is too much., Try adjusting your clutch pedal to 1/2" of free play at the top. Good luck!
Dick M is offline   Reply With Quote
Old 03-26-2013, 06:23 PM   #6
Peter J
Peter J's Avatar
Tom,
Sorry to confuse, by "forks" I meant the 6 fingers on the clutch plate are quite a ways down.
Old 03-26-2013, 06:48 PM   #7
PC/SR
The clutch fingers should be less than 1/8" from the face of the throwout bearing. I used a 6" piece of bailing wire, about .100 thick, as a feeler gauge to adjust mine. Tie a string to it because you Will drop it. This can be done in the car. Put in "adjust clutch fingers" in the Search window and lots of threads will come up.
PC/SR is offline   Reply With Quote
Old 03-26-2013, 07:49 PM   #8
Peter J
Peter J's Avatar
That baling wire sounds like a great idea! Better than dangeling a feeler guage in there. I'm to take it that fingers in too far WILL make the clutch slip a little ??
Old 03-26-2013, 08:06 PM   #9
85930tudor
85930tudor's Avatar
Send a message via Yahoo to 85930tudor
Yes the fingers in to far will make it slip
85930tudor is offline   Reply With Quote
Old 03-26-2013, 08:34 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Someone brazed a feeler guage to an old screwdriver for this purpose.
Old 03-26-2013, 08:44 PM   #11
85930tudor
85930tudor's Avatar
I used a peice of electrical coduit and flattened one end,drilled a hole and bolted the feeler gauge blade in it. works great just un bolt your feeler gauges and remove the blade you need and bolt it in.
Old 03-26-2013, 09:11 PM   #12
James Rogers
James Rogers's Avatar
Pete
This might help http://www.ahooga.com/notebook/howto/1/howto1.shtml
James Rogers is offline   Reply With Quote
Old 03-26-2013, 10:52 PM   #13
Peter J
Peter J's Avatar
James/All
Appreciate the info. and some of the tricks that sure make since. I'll do some adjusting and see what happens.
Thanks Again!
Pete
Old 03-27-2013, 07:18 AM   #14
Patrick L.
Patrick L.'s Avatar
What did you set the height at ? I don't believe you mentioned that. As Tom said, 5/8- 11/16" is fine. I use a piece of 5/8" round stock for this job. You may try reducing the amount of free-play and see if that helps. But, 1.5" of free-play is OK and the clutch should work fine. I think re-setting the fingers to a specific height while still in the car is a heck of job. Re-setting them for even contact is a different story.
Old 03-27-2013, 08:11 AM   #15
James Rogers
Free play is totally irrelevant as far as slippage is concerned. During free play the release bearing is not touching the plate and it is in as full lockup as possible. The adjustment bolts are too tight which, prevents the plate from clamping the disk fully. Tom is correct with the 5/8" adjustment from the top of the plate to the fingers.
Old 03-27-2013, 08:26 AM   #16
Patrick L.
Patrick L.'s Avatar
James is correct, I just didn't want to step on anyones toes. Personally I think the flywheel/clutch needs to come out and set on the bench.
Old 03-27-2013, 03:42 PM   #17
Peter J
Peter J's Avatar
I adjusted the forks and found about 1/16-1/32" end play probably at the bearing (which is funny since it doesn't leak a drop) when I pressed the clutch. That may be where my adjustment went. Anyhoo...............it still slips.
Oh Well,
Thanks Guys.
Pete
Old 03-27-2013, 07:08 PM   #18
RichPA
RichPA's Avatar
Pete, I strongly recommend that someone with experience put their eyes on this before you take it apart, JMO
RichPA is offline   Reply With Quote
