Old 05-25-2023, 05:25 PM   #1
Steves46
Steves46's Avatar
Default Clutch Question
Love these old cars-seems like there is always something but then again shes 93 years old. With the car running, I depress the clutch pedal, put the car in gear, and with the clutch pedal still depressed, when I take my foot off the brake, the car is in gear and moving. What is the first thing I should check? Thanks. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 05-25-2023, 06:36 PM   #2
WHN
Default Re: Clutch Question
Check your adjustment on clutch.
Enjoy.
Old 05-25-2023, 06:46 PM   #3
Steves46
Steves46's Avatar
Will do. The pedal free play just shy of an inch. Thank you.
Old 05-25-2023, 06:53 PM   #4
WHN
You need about 1” to 1.5” of free play.
Enjoy.
Old 05-25-2023, 07:10 PM   #5
Steves46
Steves46's Avatar
Gotcha. I believe if I turn the clevis counter clockwise it should increase the pedal play.
Old 05-25-2023, 07:51 PM   #6
Tom Endy
Tom Endy's Avatar
Check for a crack in the clutch shaft lever at the locking pin.
Tom Endy
Old 05-25-2023, 08:04 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Tom Endy
What Tom said...
Old 05-25-2023, 08:40 PM   #8
GRutter
GRutter's Avatar
You're on a hill :-)
GRutter is offline   Reply With Quote
Old 05-25-2023, 11:21 PM   #9
Bill G
Bill G's Avatar
Originally Posted by Y-Blockhead View Post
What Tom said...
I had that happen. Easy fix with the new levers the vendors sell.
Old 05-26-2023, 06:42 AM   #10
nkaminar
nkaminar's Avatar
It may also be possible that the clutch fingers are not adjusted equally. If I remember correctly they should be adjusted to within 0.002 inch of each other. If they are not adjusted equally one side of the pressure plate could be dragging.
Old 05-26-2023, 09:38 AM   #11
Steves46
Steves46's Avatar
Resolved. Adjusted pedal play. Thanks.
Old 05-26-2023, 10:38 AM   #12
WHN
Great!
Now go out for a drive.
Enjoy.
