12-28-2010, 11:25 PM | #1 |
Anyone have pictures & measurements of Merc pressure plate?
I just purchased a well used pressure plate that looks like a 49-53 Mercury, but I'd like some verification before I have it rebuilt and drill & tap a flywheel to match. Does anyone have pictures and measurements?
Thanks! |
12-29-2010, 01:43 AM | #2 |
Re: Anyone have pictures & measurements of Merc pressure plate?
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
12-29-2010, 11:57 AM | #3 |
Out of a '50 Merc.
12-29-2010, 12:49 PM | #4 |
I just removed one from my stock 53 Merc. It is a 9 1/2" set up. It's 9 1/2" in Diameter on the face. The flywheel is different from the earlier ones.
12-29-2010, 02:04 PM | #5 | |
You are better off to have the plate in hand before you drill and tap a flywheel. |
12-29-2010, 02:21 PM | #6 |
The old and best way to do this is with a rotary table or index head.Find the center put index at 0 degs.Then move table out to 5.8125 ---5 13/16 lock table . Spot drill,then index to 60 degs,then120,180,240,300,360 home or start.Once they are spoted repeat first opertion.The ref only between hole is 5 13/16 There is less chance of errror and easy. |
12-29-2010, 07:57 PM | #7 | |
If you have the 9 1/2 clutch, at least it makes it easier to find replacement parts. The Borg & Beck next to impossible to find new parts for. The old parts can be rebuilt though, as long as you have a good core. Kerby |
12-29-2010, 11:28 PM | #8 |
Whatever you have, make sure that the three fingers won't interfere with the "snout" on the trans that the throwout bearing rides on, especially with the fingers "compressed."
12-30-2010, 08:32 AM | #9 | |
12-30-2010, 09:05 PM | #10 |
Thanks for the replies. I had a flywheel and clutch setup but I installed it on a friend's engine. I'd like to have another, and picked up a pressure plate cheap, but don't remember exactly what the correct Mercury pressure plate looks like. Does anyone know if the Mercury pressure plate clears the bell housing on a 38 transmission and works with the throwout bearing on the same transmission?
01-03-2011, 01:15 PM | #11 |
'49-50-very early '51 Merc pieces fit. The later '51-53 won't work on early Fords because the fingers are spaced for a much smaller throwout bearing. I think there are also very similar plates, also not usable on early Ford, from early Chevy V8's.
01-03-2011, 02:02 PM | #12 |
I have a 53 merc. 9 1/2" P/P and disk with a 39 Trans. no problemo. Call FORT WANE CLUTCH & DRIVELINE at 1-800-2258-8243, they will have all the information you need on any set up and make it up for you (very cost effective and time saving).
01-03-2011, 02:42 PM | #13 |
This is the pressure plate that came out of my 53 Merc. The same is in my 53 merc. engine in a 8ba cast iron bell housing with a # 78 case, 39 transmission. I had the disk made with the 39 trans. spline. It all bolts up fine.
