Old 07-09-2016, 02:23 PM   #1
Dick Steinkamp
Dick Steinkamp's Avatar
Default Weird (to me) intake
What's with the extra "bump" on this intake?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 07-09-2016, 02:32 PM   #2
barnstuf
Default Re: Weird (to me) intake
I believe from a right hand drive Model A.
barnstuf is offline   Reply With Quote
Old 07-09-2016, 02:45 PM   #3
Dick Steinkamp
Thanks. What would the bump be for on a RHD car?
Old 07-09-2016, 02:58 PM   #4
Keith True
Keith True's Avatar
It's for a pivot,or bellcrank for the spark advance rod.
Keith True is offline   Reply With Quote
Old 07-09-2016, 03:10 PM   #5
Juggler
Juggler's Avatar
Juggler is offline   Reply With Quote
Old 07-09-2016, 03:36 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Del found a 6 year old classified paper with a Phaeton for sale WAY up North. Called & he still had it. Took a trailer & went WAY up North. SURPRISE! it was a R/H Drive! He bought it. It was GREEN & drove GOOD. He still has it.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-09-2016, 04:55 PM   #7
Dick Steinkamp
Thanks! Mystery solved!!
Old 07-09-2016, 07:17 PM   #8
Synchro909
Synchro909's Avatar
I bought my first Model A CHEAP because the PO had connected the rods to the wrong arms on that bell crank. As a result, the steering column lever was Up to advance, down to retard. Even then, because one arm is longer than the other, he couldn't get enough advance so it struggled to hold top gear on the flat. When I took delivery, I stopped just around the corner and connected them the right way and have never looked back (except at Chevs in the rear vision mirror )
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-10-2016, 12:39 PM   #9
Brad in Germany
Brad in Germany's Avatar
Default Manifold diameter for AF engines?
I have a similar manifold on my AF engine in a French (left hand drive) car.
Is the manifold smaller diameter for the AF engines?
What is that a plug on my manifold where the pivot for the spark advance would be bolted on for RHD cars? (Obviously not needed for a LHD car)
Were all AF engine manifolds like this?
Thanks for any insight,
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 07-10-2016, 01:03 PM   #10
Joe K
Joe K's Avatar
Default Re: Manifold diameter for AF engines?
Maybe smaller diameter to match the smaller bores/smaller engine displacement?
Carb venturi/jets may be different too.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 07-10-2016, 04:46 PM   #11
Synchro909
Synchro909's Avatar
[QUOTE=Brad in Germany;1321598]I have a similar manifold on my AF engine in a French (left hand drive) car.
A grease nipple??
Old 07-10-2016, 05:13 PM   #12
Dick Steinkamp
I wonder if when Ford made spares that the made all intakes like the ones shown here so they could be used on both left and right drive cars.
Old 07-11-2016, 01:18 AM   #13
Brad in Germany
Yeah, that is what I am thinking might be the case with the AF manifolds - that they are the same regardless if they are for a RHD or a LHD car.
Has anyone seen an AF manifold without the spark advance pivot bump?
Brad in Maryland.
Old 07-11-2016, 02:53 AM   #14
Synchro909
Synchro909's Avatar
Whether they made the same manifold for both left and right hand drive cars back in the day is of little help. This is just one more of those scores of things that vendors do not offer for RHD cars.
Old 07-11-2016, 08:53 AM   #15
Art Newland
Art Newland's Avatar
Originally Posted by forever4 View Post
Is there a problem with too many worn out intake manifolds and not enough replacements available?
That's what happens when you forget to grease them!
Art Newland is offline   Reply With Quote
Thread Tools
Display Modes
