Old 08-09-2020, 04:15 PM   #1
Detonator
Detonator's Avatar
Default '35 Ignition Lock, removing plunger pin?
I'm trying to pull the pin out of the Steering Wheel Lock Plunger -- some of the reading I've done calls it a "nail" -- but having no luck. Most "how-to" articles just say "remove pin..." (It's #10 on the diagram below).
Any secrets to yanking this guy out?
A second question: With this pin in place, the "plunger" will not currently retract far enough to slide the entire column drop off the column tube. Is this normal?
Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 08-09-2020, 05:17 PM   #2
Detonator
Detonator's Avatar
Default Re: '35 Ignition Lock, removing plunger pin?
Got the pin out....
Is there a source for these pins? For other parts and pieces to this assembly?
Seabright Hot Rods
Old 08-09-2020, 06:43 PM   #3
lotsagas4u
Third gen automotive
lotsagas4u is offline   Reply With Quote
Old 08-09-2020, 07:16 PM   #4
DavidG
DavidG's Avatar
Grab the pin in a small pair of vise grip pliers as tight as you can make it and then with a long shaft screw driver pry up on the the tip of the jaws of the pliers.
Old 08-09-2020, 11:34 PM   #5
Detonator
Detonator's Avatar
Originally Posted by DavidG View Post
Grab the pin in a small pair of vise grip pliers as tight as you can make it and then with a long shaft screw pry up on the the tip of the jaws of the pliers.
I grabbed the pin with a small pair of vice grips, then clamped a larger pair on and used it to pry out the pin.
Seabright Hot Rods
