08-25-2023, 11:33 AM | #1 |
Changed Coil, No Spark
I had to change the coil in my stock 51 Ford with 6V + ground system. I hooked up the ignition side to the negative side of the coil and the ground side (points) to the positive side of the coil. No spark. Is this wrong? Anybody have this problem?
08-25-2023, 12:58 PM | #2 |
Re: Changed Coil, No Spark
Was the old coil working?
08-25-2023, 02:03 PM | #3 | |
Got voltage at the coil coming from the ignition switch? Last edited by JayChicago; 08-25-2023 at 02:09 PM. |
08-25-2023, 03:37 PM | #4 |
08-25-2023, 04:12 PM | #5 |
Ok. You have voltage at the coil. You have tried two different coils. My next thought goes to condenser. Have you tried a new condenser?
08-25-2023, 05:25 PM | #6 |
