09-15-2012, 03:26 PM | #1 |
Light rod problem
Installed a new Horn/Light rod in steering column. Now the rod will not turn left or right to turn on lights, what did I do wrong. Did install new light rod bushing.
09-15-2012, 03:51 PM | #2 |
Re: Light rod problem
It looks as though the bail arm is too tight, pulling the switch harder into the switch contacts. Try a slight rebend of the wire to make it not so tight, or a little lube. If this fails, look at the way the spider connects to the switch. The 2 must go together with the spider fingers vertical.
R.H.D. Author of Model 'A' Ford technical manuals. Supplier of good original RHD parts. |
09-16-2012, 06:08 AM | #3 |
First, I would make sure that the rod turns freely with no switch installed. If so, then I would assemble the switch and check it for smooth operation using a small screw driver to turn it.
09-16-2012, 09:43 AM | #4 | |
Did you install the right size light rod?...I think there were 4-5 different lengths. PLUCK |
09-16-2012, 10:00 AM | #5 |
If the bail wire is too tight to slip over the switch you can lengthen it a bit by placing the "S" curve in the jaws of a vice so it is parallel to the top of the jaws and tighten the vice, this will reduce the amount of curve in the "S" and give you a little more length.
09-16-2012, 12:12 PM | #6 |
