Old 10-31-2020, 09:06 PM   #1
Habusailor
Habusailor's Avatar
Default Engine block
I ran across a 24 stud block with L2101 cast into the back of the block. Can anyone help narrow this down? According to Van Peldt it is an 8ba, going by the water jacket casting holes
Sent from my SM-T550 using Tapatalk
Habusailor is offline   Reply With Quote
Old 10-31-2020, 09:52 PM   #2
JSeery
JSeery's Avatar
Default Re: Engine block
Well, it is very easy to tell an 8ba from a 59ab!
Old 11-01-2020, 01:46 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
To help clear matters up, the black block with 'bolt-on' bellhousing is an "8BA" type. The blue block with the cast-in half-bell housing is a "59A" type....both blocks utilizing 24-stud heads. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-01-2020, 01:58 AM   #4
Tinker
Tinker's Avatar
There was life before the 59a also. 99 and the 81a comes to mind. There are a lot of markings on blocks, some mean something some don't.
http://www.vanpeltsales.com/FH_web/f...gs_engines.htm
Old 11-01-2020, 08:08 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
....and then there's the French FH block, which coopman doesn't show, that has characteristics of both the 59 & 8ba series blocks.
John
Old 11-01-2020, 09:31 AM   #6
JSeery
JSeery's Avatar
Couple of photos would clear this up!
Old 11-01-2020, 12:08 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
It's likely that any time someone "runs across" a French block, you're gonna be informed that it's a "$French$" block! Le moteur Francais, below! DD
T5 W/TORQUE TUBE
