10-31-2020, 07:55 PM | #1 |
1939 steering box
is there an outside appearance difference between a 35 steering box and a 39 steering box? and also is a 39 steering box the same as a 37
10-31-2020, 08:39 PM | #2 |
Re: 1939 steering box
35 looks different to 39, and 37-39 are identical
11-01-2020, 05:37 AM | #3 |
Here are 2 links.The first is a 35-36 and the second is a 37-40 so you can see the differences.
https://www.ebay.com/itm/Ford-Flathe...0AAOSwzrtfkid~ https://www.ebay.com/itm/Ford-Mercur...MAAOSwS1xfCIlz |
11-01-2020, 08:31 AM | #4 |
thank you the pix help
11-01-2020, 08:39 AM | #5 |
If you are replacing the 35-36 with the later box and using the light switch at the base you will have to use the 37-39 bracket and bale.No need to change the switch and its components.The change to the 37 and later gear gets involved also.Several threads on that subject here.
11-01-2020, 08:42 AM | #6 |
11-01-2020, 08:48 AM | #7 |
Here are some pictures I have in my files showing the differences between '36 (on right) and '37-'48 (on left) Ford steering boxes.....
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 11-01-2020 at 10:53 AM. Reason: *Correction....to 36 box on right, not a 35, and 37-48 on left. Got my left and right mixed up �� |
11-01-2020, 08:57 AM | #8 |
i assmume the bigger on is the 37
11-01-2020, 09:05 AM | #9 |
First pic JM 35 sedan posted ,the one on the left is a 37 and later and you can clearly see the difference in the light switch bracket.I did a quick search and here is a link to a thread that will get you started.I have heard that its not necessary to replace the frame bracket but drill a couple new holes on the original 35-36 to fit the later box.I have done the conversion twice and it was well worth it.I did replace the bracket with a Bob Drake repo.Originals due turn up on EBAY.Finding a good 37 and later box might be another challenge as many out there are worn out.
https://www.fordbarn.com/forum/showt...ng+replacement Last edited by deuce lover; 11-01-2020 at 09:14 AM. |
11-01-2020, 09:18 AM | #10 |
Here is a 37 and later bracket on EBAY
https://www.ebay.com/itm/1937-to-1940-Ford-steering-box-bracket/164479108963?hash=item264bb80763:g3cAAOSwrDxfnE3g Here is the 35-36 bracket ,you can see the hole location is different. https://www.ebay.com/itm/1935-1936-F...0AAOSw-xVZ6N-D |
11-01-2020, 09:35 AM | #11 |
thank you so much for all your help. it explains everything
11-01-2020, 10:18 AM | #12 |
do you use the same pitman arm when converting to the 37 box
11-01-2020, 10:56 AM | #13 |
I use the 35-36 pitman arm on the 37-48 box for this conversion.
