05-04-2020, 09:01 AM | #1 |
Crab distributor vacuum
Where does the vacuum line attach at the distributor? I know it comes off the intake but where does it connect to the 42-44 crab dist.?
05-04-2020, 09:06 AM | #2 |
Re: Crab distributor vacuum
05-04-2020, 09:09 AM | #3 |
You can see the port on the cover, top right.
05-04-2020, 11:17 AM | #4 |
Do all timing covers have that port?
05-04-2020, 11:43 AM | #5 |
No, only the covers that have 2 bolts for the distributor.
05-04-2020, 12:04 PM | #6 |
05-04-2020, 12:05 PM | #7 |
05-04-2020, 12:11 PM | #8 |
And here is the back side of that two-bolt distributor, on which you can see the tiny, corresponding vacuum port with it's sealing O-ring in place. As the distributor bolts are snugged-up, that O-ring which protrudes above the flat surface is compressed, sealing the press-fit connection. DD |
05-04-2020, 12:56 PM | #9 |
And here is picture of the adapter require when converting from a 3 bolt helmet distributor to a two bolt crab distributor (engine has a 3 bolt timing cover).... As seen on VanPelts site....
