Old 08-11-2019, 08:52 PM   #1
Steve Plucker
Default Correct placement of front and rear grease baffles...
What is the correct placement of the early front and rear grease baffles...those with the metal round spacers that are attached to them. These are the grease baffles located within the hub area next to the backing plates.
Thanks.
Pluck
Old 08-12-2019, 11:57 AM   #2
Jim Brierley
Default Re: Correct placement of front and rear grease baffles...
Not sure what you are talking about, a photo would help. Are these the approx 1" wide tin things that are there to keep grease from getting out to the linnings?
Jim Brierley is offline   Reply With Quote
Old 08-12-2019, 09:07 PM   #3
Steve Plucker
It is the orentation of the grease baffles that have the round metal spacers attached to them that are assembled to the front and rear backing plates. They can be assembled two ways...which is correct?
Pluck
Old 08-12-2019, 09:54 PM   #4
Gary WA
Gary WA's Avatar
The Henry Ford Way!
www.whidbeymodelaclub.com
Old 08-13-2019, 09:12 AM   #5
daveymc29
daveymc29's Avatar
mine has round in the front, square in the back,
daveymc29 is offline   Reply With Quote
Old 08-13-2019, 09:29 AM   #6
WTSHNN
WTSHNN's Avatar
I believe what Steve is asking is the early style baffles were different than the more common later ones and he's wondering which side goes against the carrier.
I do not know one way or the other but playing around with it I assumed the "spacer" portion of the rear baffle goes against the carrier to keep space between the carrier and baffle.
I don't have any of the early front baffles but here is a picture of one from Brattons.
https://www.brattons.com/1928-front-...se-baffle.html
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 08-13-2019, 10:49 AM   #7
Russ/40
Russ/40's Avatar
The flat section goes to the top at 12:00 and widest opening out.
I don't have any experience with the very early ones. The later ones don't have any spacers.
Russ/40 is offline   Reply With Quote
