Old 07-30-2019, 12:00 PM   #1
old31
Default repairing running board hole help
I had a hole in my rubber on the running board. I repaired the hole with JB Weld.
Does anyone know of a brush-on or spray that will make the JB rubberized like the running board, and look smooth? I would go over the entire running board with it.
Old 07-30-2019, 12:14 PM   #2
Russ/40
Russ/40's Avatar
Default Re: repairing running board hole help
First, the JB was not a good choice. Since its already there, you can conceal it with the rubber dip material available in cans in hardware and automotive stores. The stuff marketed as a rubber handle coating on pliers and such. Repeated coates will fill any void and turn flat black when cured. Do NOT attempt to cover the whole board.
I love the stuff. You will find many applications for it. I use it on the tailgate latch of my 29PU. Stops any rattles and protects the paint.
Russ/40 is offline   Reply With Quote
Old 07-30-2019, 06:34 PM   #3
30 Closed Cab PU
Thanks for the tip on PU tailgate, great idea, mine rattles a lot .
30 Closed Cab PU is offline   Reply With Quote
Old 07-30-2019, 06:34 PM   #4
old31
Thanks Russ.
Thread Tools
Display Modes
