07-17-2012, 06:57 AM | #61 |
Re: Brake parts identification and puller info Q..
Havn't read every reply, but your rear brake backplates are on the right side, but the cylinders are on the wrong side. The pipe enters from the rear. It bolts up better with the pipe entering from the front, that's probably why so many were fitted the wrong way round in the past.
That's quite a clever adaption of the shoes - but it probably throws the geometry out, the pivot points are positioned differently between early/late backplates. The shoes with the round holes are the ones you want. Mart. |
07-17-2012, 08:17 PM | #62 | |
07-17-2012, 10:22 PM | #63 |
Mart,
Thanks for pointing the 'pipe' connections (brake lines to the wheel cylinder). You've given me another problem to deal with , as I'm sure that you are correct with your accessment. Now are those lines long enough to rebend to proper cyl connection angle...if not yikes ? |
07-17-2012, 10:31 PM | #64 | |
07-22-2012, 04:03 PM | #65 |
Been 'out of commission' for several days, but today got rt/r wheel cylinder apart this morning and you can see what I found(pics). I'm determined to try and save USA made parts, but could be fighting a battle here! Couple questions:
Can I do TOO much honeing of a wheel cylinder, in your opinion/experience, or will wheel cylinder 'kit' take care of lot of honeing? also; I broke a stone on my old brake hone (hm..sounds like basis for good Ford song!)....what to do/harbor freight have stones? Hm, forgot pics.... Last edited by hardtimes; 07-23-2012 at 02:25 AM. Reason: .... |
07-23-2012, 02:24 AM | #66 |
07-23-2012, 07:07 PM | #67 |
Can anyone advise on whether these two 'emergency brake' parts/levers are CORRECT for the '39/'41 ford brakes that someone installed (poorly) on my newly acquired '36 coupe? The smaller part appears to have been 'modified'. As none of the brake system works presently..that's why I asked.
07-23-2012, 07:50 PM | #68 |
yes, looks correct, here was mine. My cylinders were just like that too. Typical of water contamination. Hone them out and see what they look like.
07-24-2012, 02:53 AM | #69 |
Thanks for the pic for comparison! Yeah, I've honed out THREE already and one to go. I feel good about the three that I've done and I'm confident that they are gonna hold fluid as they should!
I notice that your emergency brake parts have WIRE CLIPS on the two pins. Mine are FLAT (pieces of metal) clips that are squeezed together with pliers. Your spring wire clips look like easier installation. Wonder if they will stay put ?? Look at my second pic and see where I'm pointing at a pin that is integral part of brake part. This pin has about a 1/8 " wear spot indentation. Should this be brazed/welded and filed round ....or just leave as is? Last edited by hardtimes; 07-24-2012 at 02:57 AM. Reason: .... |
07-24-2012, 04:56 PM | #70 |
Backing plates nuts('39/'41) were hand tight and attached without cotter pins and no lock washers under back plate nuts. Also THREE different size back plate nuts were used to fasten them. From the picture of different nuts shown ...can you tell me which one is correct?
Also , rear axle nut has buggered threads. Is there a source for NEW, as I can not locate new. Lastly, of the 2 rear axle washers shown ...is either one correct (one on left is thick (about 3/16" or better, while other thin washer is about 2/16") |
07-24-2012, 08:22 PM | #71 |
Macs has the axle nuts here: http://macsautoparts.com/early-v8-fo...0R3CHL1129315/
I would use the thicker washer with the axle nuts. I'm not sure what nut is correct for the backing plates, but Macs has them too. http://macsautoparts.com/early-v8-fo...0HQRPG1000005/ Also, i would'nt worry about the wear on the e-brake actuator pin. As for the retainer clips, I'm not sure what would be correct. I would guess the wire clips are newer repos. They have worked fine. |
07-25-2012, 01:08 AM | #72 |
Thanks much for all that good advice/ info! A bud here also has directed me to C&G in Escondido, CA. As we discussed parts, etc...I remembered asking C&G for a catalogue on a thread here short time back! I'm anxious to get that catalogue, as it will most likely clear up parts that I need. I'll contact Macs too !
BTW- During my research, I've come across several bits of info that says that: '28 thru '48...wheel bearings and axle nuts/washers are SAME SAME. Then I come across info contridicting that ? |
07-25-2012, 08:11 AM | #73 | |
Charlie Stephens |
07-25-2012, 12:24 PM | #74 |
Hey Charlie,
Well, I should have clarified that I was seeking replacement of damaged FRONT wheel bearings/race, when I found info saying '28/'48 front whl bearings are same and contradicting info. So, Charlie ...if I find that my rear outer wheel bearings are bad...are you telling me that only '36 rear whl brngs will fit ? If so, that is good information and will narrow my research. THANKS! |
07-25-2012, 05:51 PM | #75 |
Ok, so Charlie did good, by getting me thinking and now my head hurts!
I took the attached pictures , just now, of the rear end in this '36. Occurs to me that ...if it doesn't have a '36 rear end in it, and I order parts (like outer wheel bearings that are special to '36) , I've caused myself more problems,eh! I've pictured right and left rear axle ends. Also, two pics of center section...in case that helps identify possible year of unit. NOTE: Take a look at the 'trailing arms' where they connect to axle...looks to be 'homemade' welds (clue?). There are parts numbers on BOTH trailing arms..is that right for stock?? Right side #: 4 * 68-4045 / Left side#: * 4 68-4046 BTW- if you need some other info from rearend, in order to help ID it...let me know. |
07-25-2012, 06:02 PM | #76 |
APPEARS to be remnants of the original-type arms "glued-onto" possibly later rear bells, at the least. '36 wishbones/spring hangers are not configured nor attached like what you have pictured. You might need to have a serious conversation with the seller, not withstanding the good that might do at this point. DD
07-25-2012, 06:06 PM | #77 | |
Charlie Stephens Last edited by Charlie Stephens; 07-25-2012 at 06:11 PM. |
07-26-2012, 11:45 AM | #78 |
Don't order the parts like bearings until you inspect yours, the original ones lasted forever and most of the current replacements are usually low quality.
Charlie Stephens |
07-26-2012, 01:02 PM | #79 | |
Thanks! So, I guess that of all the experts of original ford equipment/restorers on this early V8 site, no one can look at these posted pictures and identify year of this rearend Q: Are there stampings around the rear center section somewhere that can help with ID? BTW- I got in touch with Richard L , who was kind enough to view pics posted here when time allows. He also has catalogue/parts...so mabe a winner here,eh ? NOTE: Got the last backplate/drum off yesterday. Found a bolt..size of little finger...lying down between drum/shoe AND same mickey mouse setup as pictured earlier for lower shoe adjusters...and ALL backplate bolts finger tight with no cotters,etc This driver just won't drive |
07-26-2012, 02:46 PM | #80 | |
Charlie Stephens Last edited by Charlie Stephens; 07-26-2012 at 03:12 PM. |
