03-04-2015, 06:58 AM | #1 |
Cam embarrassment
With 50yrs of engine machining this is embarrassing. Installed Federal
cam bearings with KRW tooling. New Genuine Ford cam we had in stock from the dealer back when. Installed the cam with Ford cam lube ok it turns by hand freely but when you stop, you need a bar to get it spinning again (by hand) We have blued the cam no highs or lows. We have checked cam on a lathe with test indicator-perfect, we have checked block cam bore alignment again perfect bearing clearance right on spec. We have run it in with a 1/2 drill along with dripping oil down the mains. The oil pump idler is free and also new. When the drill stops, again its pry bar time again then will turn by hand freely. Any thoughts; Also the shop is kept at 65 degrees at night. This is a first, also its a std EAB that is perfect as perfect can be. Although there is always a reason for a problem, but this one won't fly with me. We built up 100's of these when flatheads were the king on oval racing, so, been there, but not this. I'm itchy about using that helper stuff, i have never have no one has it round here anyway. sam |
03-04-2015, 07:03 AM | #2 |
Re: Cam embarrassment
Do you have another cam, used maybe, to try? Then you would know if it is the cam or the block.
03-04-2015, 07:13 AM | #3 |
I have encountered similar problems when the end of the bearing swelled(deformed very slightly) when contacted by the installation tooling. A precision dial bore gauge can be used, with careful manipulation, to determine status at the end where the camshaft enters the bearings. It will probably be ok without adjustments but I use a lightly tapered mandrel to correct.
03-04-2015, 07:19 AM | #4 | |
but we cant find anything wrong with these and we do not use over the pond parts just US name brand.....sam |
03-04-2015, 07:47 AM | #5 |
Have you checked with the oil pump idler removed?
03-04-2015, 07:51 AM | #6 |
Dan Kingman Az. 86409 |
03-04-2015, 07:57 AM | #7 |
Remove the oil pump and see what happens.
03-04-2015, 08:10 AM | #8 | |
is a nice free by hand spin then stop then it wont turn unless pry bar then spins freely again is that clear as mud? not being wise guy, but it aint clear as mud to me. I know my mics/measuring, this is annoying me. Next thought is, after valve train installed "with this tight start; not good for the cam fibre gear plus oil pump load" yes / no I know lowrider we did 3 272's Y and one 332 Y truck Lincoln last year. uggg I shall conquer this |
03-04-2015, 08:12 AM | #9 |
03-04-2015, 08:13 AM | #10 |
03-04-2015, 08:20 AM | #11 |
After you've pry bared it, are there any shiny bits on the bearings?
Martin. |
03-04-2015, 08:22 AM | #12 | |
is we cannot find anything wrong-but somethings wrong Its not my engine thinking if mine = wrap it up run it and then ? (aint got the heart flatheads are my purrring cats) |
03-04-2015, 08:25 AM | #13 |
Here's just another spitball:
When the cam is in motion its being thrust by the oil pump idler into a certain position. When it stops turning, it relaxes into a different (Fore/Aft) position. That relaxed position has a burr or other defect on one (or more) cam bearings. Have you tried spinning it backwards with a reverseable drill? |
03-04-2015, 08:26 AM | #14 |
Fuel pump bushing interference? Or Sounds like a thrust type hang up, is the front bushing flush with the block?
03-04-2015, 08:33 AM | #15 |
Quality control
Along with our cam situation, our engines are mainly V8 T's and A's
come out the door totally silent. So munch as I can hear the cam clicking on the points and or fan belts. Proof; my wife wiped out a starter cause she could not hear it running thats my stamp of appoval.. s d pine & sons we do 350's 337's 446's husdons chrysler marine too |
03-04-2015, 09:47 AM | #16 |
Clean off the bearings and cam,use a little lay out fluid on bearig surface move the cam front to back and see if there is a high spot or tapered area, I seen one case where the bearing bore had a small burr left from removing the old bearings causing the new bushing to form a conical shape toward the rear and when the cam thrust to the rear a substantial drag was present, like Mke 51 Merc said.
03-04-2015, 09:54 AM | #17 |
Not a great mechanic but could the cam have a slight warp to it?
03-04-2015, 10:21 AM | #18 |
Do you have the same results if you install cam and then push it 1/2 way out and observe the tight spot as being the same.
R |
03-04-2015, 10:41 AM | #19 |
My guess would be that one of the bearings is off center on the bearing ID. This would cause an alignment problem that would be hard to find. Even though manufactured in the USA, they can make mistakes too.
03-04-2015, 10:49 AM | #20 |
I've seen a few things like this - tends to be something in the bearings, dragging on the cam journals. Something is malformed . . . someplace . . . and most likely a bearing.
I'd clean the heck out of everything and really inspect the bearings - there has to be a shiny spot on at least one of them. You could try a bit of die-chem on the cam journals - then see where it rubs off. Also, maybe you first try it with just 2 of the 3 journals in the bearings . . . any binding yet? Then put the cam all the way in. You'll find it - just need to look closer! |
