10-10-2017, 02:32 PM | #21 |
Re: exhaust crossover and pressure testing
here's the pics from my afternoon yesterday. spent 2 months asking around for the "proper tool" or a recommendation for a shop when I should have done this from the beginning. took me a couple hours to make it up and test both sides.
10-10-2017, 02:45 PM | #22 |
The only problem with using the heads for pressure testing is that you can't tell where the cracks are as well as you can with plates if properly made. If a person doesn't want to pin the leaky cracks then it won't matter much. Some cracks are in places that can't be pinned anyway like the ones down inside the center exhaust port area. If it's in the valve pocket and doesn't go too far down into the bowl, it can be pinned. Most exhaust valve seat area cracks can be seen with the naked eye so that's the first place I check.
10-10-2017, 02:50 PM | #23 | |
10-10-2017, 07:09 PM | #24 |
Ok.. just picked up a stock rebuilt 8ba never fired! Got a good deal. Swap out my stuff and go!
10-11-2017, 12:30 AM | #25 |
Sorry about the test results, but sounds like you have another Candidate ready to go. There are plenty of flatheads still out there.
I was going to put a 40 motor in my 35, but procrastination led to a low mileage 59AB that fell in my lap! |
