Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 05-03-2016, 08:10 PM   #1
FordCustom
Default Tie rod "standards"?
Is there a recognized safe limit for amount of threads captured in the clamped section of the crossbar? I have a 50 F-1 which needs dropped tie rods, because a 3 inch dropped axle. Not asking for specifics, but what's the minimum threads installed? I have to cut the cross bar down, since the new tie rods are much longer. Right now the stock setup is 48 3/4" center to center. a good enough point to start, but I want to be sure and cut it correctly. IE: a safe amount of threads.
FordCustom is offline   Reply With Quote
Old 05-17-2016, 08:38 AM   #2
Gabriel Shirley
Default Re: Tie rod "standards"?
I cannot tell it for sure, but you can pose that question to professionals. There is one website where your all questions will be answered.
Expertat fast essay writing , Gabriel.
Gabriel Shirley is offline   Reply With Quote
Old 05-17-2016, 10:58 AM   #3
FordCustom
You're so awesome, thanks!!!! This is what you use your first post for?
Old 05-17-2016, 10:59 AM   #4
FordCustom
Or are you a spam bot. Most likely. Got any fresh Ray Ban ads for me as well?
Old 05-17-2016, 06:21 PM   #5
tinman080
tinman080's Avatar
Thread 'em in a minimum of the shaft size, better with 1/2 again as much added on. A 1/2'' shaft I would thread in no less than 1/2'', better if 3/4''. This is based on my observations over many years of changing damaged tie rod ends. Not recommending, this is a decision made by the owner. I've changed them with 2 threads screwed in, and with them bottomed out. People attempt to avoid replacing bent spindles by over adjusting tie rod ends.
Just Passin' Thru.....Slowly!
tinman080 is offline   Reply With Quote
Old 05-17-2016, 11:18 PM   #6
Lanny
Lanny's Avatar
FordCustom, just a note to say that this section is
for Questions and Suggestions to the EDITOR , about this site.
If you place your question in the "Early V/8 Discussion" forum here, you
will get more than just one or two replies to your question, which equals
more members to help you with your question. good luck.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
