10-11-2012, 11:15 PM | #1 |
Exact build date?
Hi where can I go to find out the exact build date of an A frame that I have? The number is clear enough to read. I want to find out the year and month and hopefully the day?
Thanx Ghost
[email protected] |
10-11-2012, 11:23 PM | #2 |
Re: Exact build date?
Go to Steve Plucker's web site and look at his tables for engine numbers. The same number was stamped on the frame rail. Go to the bottom of the page and click on the link for the engine numbers 1928-1931.
http://www.plucks329s.org/studies/studies_ep/studies_ep.html Or go with this link http://www.plucks329s.org/pdf/studies/Model%20A%20Daily%20Motor%20Production%20Charts.pd f |
10-11-2012, 11:56 PM | #3 |
Ray White |
10-12-2012, 05:56 AM | #4 |
Umm, I kindly disagree that the engine numbers will tell you an exact frame build date. Even if the number on the frame was legible, this still does not give an indicator as to the frame build date as the engine was manufactured at Rouge and had to be shipped to the Branch. Depending on travel time to the Branch, their sales volume, and inventory distribution of the engine as it was placed onto the assembly line would affect dates. Therefore the swing could be 60-90 days.
10-12-2012, 08:29 AM | #5 |
Frame features along with the engine date could help narrow down the date
10-12-2012, 08:40 AM | #6 | |
I'm guessing my car probably sat around awhile on a lot in 1930 due to the stock market crash that happened during it's production on top of that.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
10-12-2012, 09:23 AM | #7 |
The Model A Ford Judging Standards and Restoration GuideLines revised 2011, in Area 1 Engine Compartment states that "the assembly date for a vehicle may be as long as three months after the date the engine was produced (four months in 1931)"
Thus with the engine number you could determine approximately when the car was assembled. As to the actual build date of the frame it could be within the same lag time as the engine. Last edited by 160B; 10-12-2012 at 03:13 PM. |
10-12-2012, 09:30 AM | #8 |
How about frame numbers..Is there a place to check them too? my car has a different frame number than what is on the engine. And the number is stamped on the bottom of the frame. I thought they were stamped on the top of the frame.
10-12-2012, 09:43 AM | #9 | |
The only numbers I have seen stamped on the underside was on a 1930 Roadster that the previous owner re-stamped so he could get the car through an inspection for an out of state title transfer |
10-12-2012, 02:24 PM | #10 | |
Charlie Stephens |
10-12-2012, 04:09 PM | #11 |
THANKS you guys as usual "A" (get it? lol ) ton of great info. Well that was easy now I just feel stupid lol May 8th 1930
[email protected] Last edited by Ghost of elmirage; 10-12-2012 at 04:40 PM. |
