Old 08-21-2012, 03:37 PM   #1
cmbrucew
cmbrucew's Avatar
Default 97 carb
Has any one sleeved the accelerator pump well?
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-21-2012, 07:58 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: 97 carb
No one?
Well I bored it with a new 11/16" end mill.
Then I turned a piece of yellow brass .625" id, and .698" od.
Will finish the od tomorrow.
Pictures I hope.
Bruce
Works good
Lasts long time
Old 08-22-2012, 12:49 PM   #3
uncle max
uncle max's Avatar
Default Re: 97 carb
This should be interesting...
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 08-22-2012, 12:51 PM   #4
Bruce Lancaster
Default Re: 97 carb
So...what is going on here? Damaged casting?
Bruce Lancaster is offline   Reply With Quote
Old 08-22-2012, 02:28 PM   #5
cmbrucew
cmbrucew's Avatar
Default Re: 97 carb
There were corrosion pits in the lower 1/2" of the well.
The sleeve is in and the slot cut down to original depth.
Looks good to go.
I will try to post pictures when it is finished.
Bruce
Works good
Lasts long time
Old 08-22-2012, 04:04 PM   #6
uncle max
uncle max's Avatar
Default Re: 97 carb
[QUOTE=cmbrucew;484285]There were corrosion pits in the lower 1/2" of the well.
Looks good to go.
Bruce
Works good
Lasts long time
This is what happens when people use 97's to collect rain water for their indoor plants... If you're successful with the repair - and willing - I might send you a few from my bonepile.
Old 08-30-2012, 08:10 PM   #7
cmbrucew
cmbrucew's Avatar
Default Re: 97 carb
Here are some pictures. Ready to cleanup and reassemble.
Thanks to Uncle Max for the help
Bruce
http://s1118.photobucket.com/albums/k617/cbrucew/
Works good
Lasts long time
Old 08-30-2012, 08:46 PM   #8
1937pickup
Default Re: 97 carb
Impressive job-you have real tallent.
1937pickup is offline   Reply With Quote
Old 08-30-2012, 10:29 PM   #9
bbrocksr
Default Re: 97 carb
Excellent!
Bill
bbrocksr is offline   Reply With Quote
Old 08-31-2012, 04:15 PM   #10
cmbrucew
cmbrucew's Avatar
Default Re: 97 carb
Cleaned up everything, and reassembled. From the speedway master 97 rebuild kit
I was unable to use;
jets
needle valve and seat
Accelerator pump
$43.00 for gaskets?
Its all good. Starts good, runs, and does not leak.
Bruce
Works good
Lasts long time
Old 09-01-2012, 09:50 AM   #11
dude
dude's Avatar
Default Re: 97 carb
Fantastic save. Are you going to be doing any for customers??
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 09-01-2012, 10:50 AM   #12
Enbloc
Enbloc's Avatar
Default Re: 97 carb
Nice repair!
Enbloc is offline   Reply With Quote
Old 09-01-2012, 11:57 AM   #13
cmbrucew
cmbrucew's Avatar
Default Re: 97 carb
Hi Dude
I have been retired 13 years, and do not have any customers.
I will have to drive the car for awhile to see if this modification is sucessful.
Bruce
Works good
Lasts long time
Old 09-01-2012, 12:19 PM   #14
hardtimes
hardtimes's Avatar
Default Re: 97 carb
Hey Bruce,
Wow...talent/skill! You retire slightly before I did. I still wish you lived closer..mabe some of that skill would learn by osmosis.eh ! Very nice work. If you need a nice 97, let me know! Regards
hardtimes is offline   Reply With Quote
Old 06-10-2015, 03:59 PM   #15
Fordestes
Default Re: 97 carb
GREAT JOB !!
how much interference fit on the sleeve to carb body, Did you use any type of sleeve setting compound? or just a dry press fit?
Fordestes
Fordestes is offline   Reply With Quote
Old 06-10-2015, 07:40 PM   #16
quickchange34
quickchange34's Avatar
Default Re: 97 carb
Jut saw your post and you are right on the money cmbrucew the brass works great for a long term fix.Its harder than the die cast and easy to machine.
quickchange34 is offline   Reply With Quote
Old 06-10-2015, 07:53 PM   #17
cmbrucew
cmbrucew's Avatar
Default Re: 97 carb
Fordestes
I don't remember. but I did put a light cote of locktite on before pressing in.
Much easier to buy a body from Uncle Max.
Bruce
Works good
Lasts long time
Old 06-10-2015, 09:30 PM   #18
39topless
Default Re: 97 carb
Told the misses about this sleeving business. She's not interested.
39topless is offline   Reply With Quote
Old 06-10-2015, 09:46 PM   #19
ford38v8
ford38v8's Avatar
Default Re: 97 carb
OOOoooooooooo!
Alan
