Old 09-25-2017, 11:36 PM   #21
wingski
wingski's Avatar
Default Re: head that won't budge
The head is off. Two super sharp hunting knives and a small ballpeen hammer did the trick, but thanks for all the advice.
Mike
wingski is offline   Reply With Quote
Old 09-26-2017, 01:07 AM   #22
H. L. Chauvin
Hi Mike,
Inexpensive handmade hardwood wedges, (oak or maple), always worked for vintage mechanics to remove heads off of "all" vintage heads on "all" types of vintage engines; however:
1. Today, first problem is finding someone today with enough talent to make several wood wedges; and,
2. If handmade wedges or even if wood wedges were sold by Model A parts suppliers, second problem would be finding someone who knew how to drive in wood wedges between the head & block to maintain metal faces of head & block parallel at all times with all head stud holes perfectly aligned with head stud bolts.
Glad you got it off.
H. L. Chauvin is offline   Reply With Quote
Old 09-26-2017, 07:40 AM   #23
Railcarmover
Originally Posted by H. L. Chauvin View Post
Hi Mike,
Wood wedges are easy,the hard part is tying the stone to the stick to fashion a striking instrument...cavemen have been gone for years..
Railcarmover is offline   Reply With Quote
Old 09-26-2017, 08:06 AM   #24
marc hildebrant
marc hildebrant's Avatar
I would not want to damage a useful hunting knife. Hopefully that knife's were not in good shape ?
Marc
marc hildebrant is offline   Reply With Quote
Old 09-26-2017, 08:07 AM   #25
barkleydave
barkleydave's Avatar
Great you got it off... I changed my head this spring. Used... engine start putty knife then wood wedges only on corners... took some time.. As all have said. PRY ONLY ON THE 4 CORNERS NOT IN THE CENTER.
Also I used a small Dead Blow hammer they work great
barkleydave is offline   Reply With Quote
Old 09-27-2017, 10:29 PM   #26
29er
29er's Avatar
I made my own head puller based on this instructive video:
https://www.youtube.com/watch?v=MtgvnT6ab0U
29er is offline   Reply With Quote
Old 09-17-2018, 10:30 AM   #27
Brendan
Brendan's Avatar
Originally Posted by zzlegend View Post
What ever you do,,,,,,,,don't put small pieces of rope in the cylinders thru the spark plug holes and crank it over as some people recommend. Just my 2 1/2 cents.
people say that all the time! i would like to see what it will brake
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 09-17-2018, 03:53 PM   #28
Tom Wesenberg
Tom Wesenberg's Avatar
It can crack or deform the piston skirt, and might bend a rod if enough force is used.
