Old 12-04-2019, 07:08 PM   #1
Ian1932
Ian1932's Avatar
Default Painting Copper Brake Lines
WAIT! These lines are almost 90% copper. They are 1/4" NiCop which is a modern product MADE for brake lines!
So, im looking these lines and as neat as i try to be it looks like crap to me. I think i want to take them off and paint them black along with the brass unions. I havent tightened anything yet, all just finger tight. Maybe scuffing them with scotch brite, taping off the ends, some epoxy primer and then some black rattle can? Anyone do this or am i over thinking it? Its like a sore thumb...
Ian1932 is offline   Reply With Quote
Old 12-04-2019, 08:47 PM   #2
TJ
TJ's Avatar
Default Re: Painting Copper Brake Lines
I think the copper will eventually oxidize and not be as noticeable. I would just leave it alone.
Old 12-04-2019, 09:46 PM   #3
34PKUP
34PKUP's Avatar
You mean that when they turn green, they will be less noticeable?
34PKUP is offline   Reply With Quote
Old 12-04-2019, 10:25 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Considering that the brake line is 90% copper, what I have used is this to blacken copper in the past.
If it works it would probably be a more durable finish than paint.
Might be worth a try.
Old 12-04-2019, 10:31 PM   #5
tubman
tubman's Avatar
I'm no metallurgist, but I believe the addition of the nickel to the alloy changes everything. One of the major advantages of NiCopp is it's resistance to corrosion. I don't believe it has much in common with unalloyed copper at all. Plus, I kind of like the look of it.
tubman is online now   Reply With Quote
Old 12-04-2019, 11:56 PM   #6
cas3
the solution is to drive it alot so its dusty and no one notices
Old 12-05-2019, 02:15 AM   #7
redmodelt
redmodelt's Avatar
Who is going to see them once the body is on?
Old 12-05-2019, 08:51 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
The same Aluminum Blackening will work on brass also.
Old 12-05-2019, 09:27 AM   #9
richard crow
i had a 1930 chrysler the car had factory copper brake lines never had a prolbem car is still driven today.chrysler never made a car with mechanal brakes
richard crow is offline   Reply With Quote
Old 12-05-2019, 09:52 AM   #10
Kube
Kube's Avatar
Ian, I think you are thus far doing a nice job with this project and I commend you.
The lines? My vote? Leave them. I like the detail shown in the different finishes. That's one major reason I paint my cars a color (no guys - black is not a color) - the appearance of the black frame, etc. against a colored floor pan, hmmm, hmmm, hmmm
Keep up the good work and please, keep us updated on your progress.
Old 12-05-2019, 11:17 AM   #11
19Fordy
19Fordy's Avatar
Let them be as they are and naturally age.
If you paint them they will look terrible when the paint begins to chip.
Old 12-05-2019, 11:43 AM   #12
Terranova
1. They'll look great from my couch.
2. Especially once the body is on
3. My dad always said, "if they're close enough to see that (meaning under your car) they need to be punched". (Assuming this car is for driving and not judging.)
Terranova is offline   Reply With Quote
Old 12-05-2019, 12:06 PM   #13
Y-Blockhead
Y-Blockhead's Avatar
Or they also make "Brass Black".
Old 12-05-2019, 12:33 PM   #14
philipswanson
Replace them with stainless and be done with it. Not that expensive. Recommend Classic Tube custom bent to fit. Easy job.
philipswanson is offline   Reply With Quote
Old 12-05-2019, 02:14 PM   #15
51 MERC-CT
51 MERC-CT's Avatar
Yes, I know that they have "Brass Black" but at the time I had 'Aluminum Black' and figured I would try it and it worked. (might be the same stuff with a different label)
Old 12-06-2019, 12:03 AM   #16
Tinker
Tinker's Avatar
I have not seen the pictures, but I agree. copper looks great against black. Technically black is the absence of color. But it is a color really. Same as white, total light. Both effect color. But correct, tradition sense is black and white is not a color in certain circles. My truck is black.
To go off topic. Black doesn't technically reflect light so it's considered not a color. But we see it. But we don't see ultraviolet light. Maybe that's not a color, butterflies do see it... and maybe if we could see it we would be filled with air that has color and couldn't see our hand in front of our face.
Old 12-06-2019, 09:48 AM   #17
Not George
Not George's Avatar
Copper turns black after green. At least the new copper roofs in my neighbor hood did.
Not George is offline   Reply With Quote
Old 12-06-2019, 10:52 AM   #18
Bored&Stroked
Bored&Stroked's Avatar
Since a 32 Ford never had any hydraulic brake lines in the first place - they will always stand out a bit.
I would not use regular paint as we all know what brake fluid does to paint - it won't last at the connections to the rear wheel cylinders. Once the paint starts to lift - it will really look like crap.
I like the looks of nicop lines - I think it will be just fine once you get the body on it and let them age just a bit.
Old 12-06-2019, 11:03 AM   #19
Mr. Will
Mr. Will's Avatar
I used that new material on both my 35 and 36 and thought it looked great.
File Type: jpg Brake Line Rear Backing Plate Driver.jpg (79.0 KB, 47 views)
Mr. Will is offline   Reply With Quote
Old 12-06-2019, 11:11 AM   #20
34PKUP
34PKUP's Avatar
Really?
Wonder how many years it will take for this statue to turn black.
