Old 12-03-2017, 07:54 PM   #41
Ian1932
Ian1932's Avatar
Default Re: Building Some 1932'S - Come Along for the Ride
Originally Posted by Mart View Post
Chassis looks really nice. You seem to be taking the parts directly to a finished state. Not criticising, but many people (myself included) will dry build the car first, where any fitting and mismatch of parts problems can be identified and rectified, then tear it down for the finishing of all the parts and the final buildup.
It would be unfortunate to have to modify or alter parts that have already been finished to a high degree, and your prep of the frame seems to be going above and beyond what I would call normal amateur prep.
Keep it up, though, you are doing good work and demonstrating excellent techniques.
Mart.
The body is together on another frame with the doors on it, the frame it is on is really really rough but it also has never been cut or welded. The deck lit was on it years ago. The hood that i have was also part of this car. Painting is the easiest parts for me, so, im going for it! Im sure i will run into something but i really want to get this done while my father is around. I want to have a drive-able car that is in finish paint. I have all the running gear ready to bring to my house and prep hopefully in a week or 2.
Ian1932 is offline   Reply With Quote
Old 12-03-2017, 11:10 PM   #42
DavidG
DavidG's Avatar
Mart,
Do you mean to tell me that they don't always go back together as planned? My word, I've never heard of such a thing. (Heard, perhaps not, but experienced, yes, nearly every time.)
Old 12-07-2017, 06:20 AM   #43
Ian1932
Ian1932's Avatar
Grill shell and hood component ready for a final cut with 500 and them topcoat unless i for whatever reason need to build it a little more. Frame is almost all iced and should be ready for final 2K priming on Sat. I have running gear that im going to be prepping for paint. I do need to straighten a couple radius rods. Pretty excited to see the seats! they are supposed to be done early next week...
Old 12-07-2017, 09:59 AM   #44
JSeery
JSeery's Avatar
Looking good!
Old 12-09-2017, 06:58 PM   #45
Ian1932
Ian1932's Avatar
So...I went hunting running gear...Everything is such a pain in the rear to get to. So i just stole the it from the 5w. The frame on this car is so perfect as far as rust goes. It does have some cuts where my dad made some mods. Remember he was a kid when he had these cars and they probably were not rare. He wanted hot rods to im sure @ one time in his life. I should have use this frame but im going to need to weld on the 5w body and the doors close and fit so nice i dont want to move it. I did take take all bits and pcs of the running gear and motor mounts. I do have everything to make another rolling chasis @ a later date. Plus, i really wanted the drop axle for the roadster. He must have added the tube shocks in the rear at some point, im not going to use those. Im still debating on the later brakes...I hope i can find enough "stuff". I found a box with about 12 pairs front spindles...Didnt see any backing plates but im sure they are somewhere....Frame is ready for final primer. Hopefully it will be in final paint in a week or so. Weather depending..
Old 12-09-2017, 09:03 PM   #46
zzlegend
zzlegend's Avatar
Been following your post Ian. Work looks very nice. Good luck with it.
zzlegend is offline   Reply With Quote
Old 12-21-2017, 02:56 PM   #47
Ian1932
Ian1932's Avatar
Something Painted Finally !!!!
Old 12-21-2017, 03:07 PM   #48
mfagan
mfagan's Avatar
Making great progress!!
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 12-22-2017, 08:10 AM   #49
Ian1932
Ian1932's Avatar
Thanks
Old 12-22-2017, 04:54 PM   #50
FlatheadTed
FlatheadTed's Avatar
Wow I can see you can paint alright ,I like the color
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-22-2017, 05:05 PM   #51
Ian1932
Ian1932's Avatar
Thanks for the compliment! There are only 2 things i like more than spraying paint
1. Natural blondes
2. Spraying Clear coat
Old 12-22-2017, 05:32 PM   #52
Ian1932
Ian1932's Avatar
Finally a frame ready for a final cut and then final paint!
Old 12-22-2017, 07:32 PM   #53
Pat/Ohio
Pat/Ohio's Avatar
That frame looks really nice! Should finish great! Thanks for bringing us along! Pat
Pat/Ohio is offline   Reply With Quote
Old 12-23-2017, 04:05 PM   #54
Ian1932
Ian1932's Avatar
Seats are done! Girl did a really nice job and she was half the cost of everyone else! Really happy with it! Also, spent all last night sandblasting stuff. Takes forever with a baby blaster and cabinet....
Old 12-23-2017, 05:26 PM   #55
noel_808
Ian, this is what it's about, building cars with family and seeing results. Can't wait to see the final product, whoever is doing the work, top notch
noel_808 is offline   Reply With Quote
Old 12-23-2017, 05:40 PM   #56
Ian1932
Ian1932's Avatar
Thanks! I assure you will be doing ALL the work with the exception of the seats getting covered...Thanks for watching and the compliments!
Old 12-25-2017, 10:32 AM   #57
Ian1932
Ian1932's Avatar
Fun this to come across on Christmas morning!
NOS V8 Rad in a wooden crate that will go in this car.
A new muffler. Not sure if this is NOS or not. Box looks really old though...
Old 12-26-2017, 01:34 PM   #58
Ian1932
Ian1932's Avatar
Sorry, i cant cant take enough pictures of this...New Seagull grey and fresh Urethane...I just screwed it all together and successfully painted the hoods today...
Old 12-26-2017, 01:52 PM   #59
TagMan
You've seem to have made more progress in the month you've been posting, than I have in a year - I'm sooooooo jealous ! I envy your enthusian, energy and talent you obviously have. I've been working on mine for over 6-years, but life seems to thwart me every once in a while.
Just a caution, if you don't mind. Don't let the project become "work" or you'll wear yourself out. The destination will be wonderful to behold, but enjoy the ride, too !
TagMan is offline   Reply With Quote
Old 12-26-2017, 02:21 PM   #60
Ian1932
Ian1932's Avatar
Thanks for the compliments! I know im driving @ this pretty hard. It just needs to be done this way. Im sure i will stay motivated. I normally stay are target once i decide to do something...Thanks for watching...
