11-09-2017, 11:17 AM | #1 |
Electrolytic/Electrolysis rust removal
Am about to set up a 45 gal barrel, have it on wheels to move from unheated storage portion of shop when not in use to heated ventilated area when I want to use it. No doubt the solution will freeze when not in use and stored in the unheated section of shop, will this freezing damage the solution ???
11-09-2017, 11:41 AM | #2 |
Re: Electrolytic/Electrolysis rust removal
I don't know the answer, but will this help?
You can go to their home page and email them for more info. http://www.myfordtractors.com/electrolysis.shtml Last edited by 19Fordy; 11-09-2017 at 11:48 AM. |
11-09-2017, 12:12 PM | #3 |
That's a good writeup on the process.
There are some good videos on uTube as well that inspired me to use for gas tank cleaning. It has good warning: NEGATIVE LEAD: Hook the wires up backwards and your vintage part will become sacrificial! |
11-10-2017, 08:04 AM | #4 |
Thanks 19fordy, that looks very informative, am guessing if I store the mixture and it freezes and is not as effective it not a costly loss for the cost of baking soda
11-10-2017, 08:42 AM | #5 |
I'd guess that the solution would have a lower freezing point a bit lower than pure water, since the electrolyte is sodium carbonate.
I don't think freezing could harm the solution. It might cause some separation, but nothing that couldn't be fixed by stirring it up. |
11-10-2017, 08:45 AM | #6 |
