Old 12-02-2019, 05:52 PM   #1
LeRoiGross
Arrow Brake Light Switch
I keep having trouble with my repro brake light switch. It doesn't make good contact inside. Is there a better design out there?
LeRoiGross is offline   Reply With Quote
Old 12-02-2019, 06:08 PM   #2
Rod-MI
Rod-MI's Avatar
Default Re: Brake Light Switch
Yes Snyder's and Brattons sell a correct copy of the original
STOP LIGHT SWITCH 30-31
A-13480-BOR 30-31 $49.95
Rod-MI is offline   Reply With Quote
Old 12-02-2019, 06:34 PM   #3
Jacksonlll
Jacksonlll's Avatar
At least take it apart and see what the problem is before you spend $50. So simple, you should be able to fix it.
Old 12-02-2019, 06:55 PM   #4
Gary Karr
Gary Karr's Avatar
But, which brake light switch are you referring to?
Gary Karr is offline   Reply With Quote
Old 12-02-2019, 08:49 PM   #5
LeRoiGross
Arrow Re: Brake Light Switch
I should have remembered that there at least 2 switches out there. I have a 29 and I may have fixed it by bending the contact inside. Still seems like a marginal design that will keep bugging me.
Old 12-03-2019, 08:56 PM   #6
TerryH
TerryH's Avatar
Years ago I had an issue with mine, and Tom Endy recommended I buy one from A&L, as it has a bronze bushing that will last and never bind. Have had mine now for almost 14 years....a great product!
TerryH is offline   Reply With Quote
Old 12-03-2019, 10:35 PM   #7
Jeff/Illinois
Jeff/Illinois's Avatar
Terry I think that is the one that Snyder's and Bratton's is sourcing, from A&L.
You know it will be right
And, 50 bucks for a good switch is cheaper than being rear ended.
Old 12-07-2019, 11:13 PM   #8
father-son
A&L only has 30-31's; 28-29's are of course different.
father-son is offline   Reply With Quote
Old 12-08-2019, 12:58 AM   #9
Synchro909
Synchro909's Avatar
Here's another thing the vendors don't have - any of them. The light switch you guys use on the '28 and 9 cars - the ones that attach to the side of the gearbox don't fit a RHD car. What was used originally on a RHD car and wil lthey ever do anything about it? I doubt it.
FWIW, I attach a plate in the corner formed by the cross member and the chassis rail and mount a LHD switch on that. I connect it to the brake pedal with a short piece of light chain. The connection has to be flexible so when the brakes are off, the chain can asg and not push itself off the switch.
Old 12-08-2019, 03:27 AM   #10
updraught
updraught's Avatar
https://www.oneillvintageford.co.uk/..._2d13480_2dRHD
Like this?
updraught is offline   Reply With Quote
Old 12-08-2019, 06:25 AM   #11
Synchro909
Synchro909's Avatar
Originally Posted by updraught View Post
Wow, not at that price!
Old 12-08-2019, 06:54 AM   #12
PalAl
PalAl's Avatar
This may help make a repair and save a buck or two. Hope it helps
PalAl is offline   Reply With Quote
Old 12-08-2019, 07:13 AM   #13
updraught
updraught's Avatar
In this day and age I'd buy a newer switch from Speedway and connect it up like the Model T guys do. And use LED stop lights. It's under the floor, nobody can see it.
Be seen, be safe.
Old 12-08-2019, 10:40 AM   #14
father-son
Thanks PalAl; great article. We had problems with our first 29 switch. The Vintique one had a short plunger. We ordered a second one from another vendor and it had a longer plunger, now all good. I will say there is a very small clearance between the contacts and the mounting screws for electrical connections can sometimes move the internal contacts.
Old 12-08-2019, 02:46 PM   #15
Synchro909
Synchro909's Avatar
Be seen, be safe.
Speedway???
Old 12-08-2019, 04:50 PM   #16
updraught
updraught's Avatar
Speedway???
Something like this.
https://www.speedwaymotors.com/Speed...itch,1972.html
Old 12-09-2019, 12:32 AM   #17
Synchro909
Synchro909's Avatar
OK, now I think I have it. The reson I haven't heard of them is they are US based.
Old 12-09-2019, 12:58 PM   #18
jrelliott
jrelliott's Avatar
You can repair the switch by taking it apart and bending the contacts so they touch better. I also found some brass tubing about 1/4" long and soldered it at both ends of the switch housing where the plunger goes through the housing so the plunger could not slip out of the housing. Been working for 10 years now.
Old 12-10-2019, 01:44 AM   #19
apbright
apbright's Avatar
Hi folks,
I recently had to repair even the A&L US-made brake light switch with the brass bushings, even after only ~6 months of daily use. I was not very happy about that, for, given that one has to severely deform and re-deform the sheet metal tabs in order to open and re-close it, I have the feeling that only one or two repairs are going to be possible.
-A
apbright is offline   Reply With Quote
Old 02-13-2020, 06:22 PM   #20
37 Coupe
37 Coupe's Avatar
Originally Posted by apbright View Post
Hi folks,
-A
I wonder what symptoms you had with your switch? Mine works on first braking but as plunger moves to furthest out no brak lights. I jumped contacts so I know it must be the switch.It is the $49.95 one from Bratton's and has yet to get me out of the garage.Thinking about one of those Ampco NORS ones on Ebay now and then next if Bratton's won't help.Trouble is I have had the switch for year now and just hooked it up.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
