01-01-2019, 01:24 PM | #21 |
Re: Hi, new here and looking for trailer advice
Yes, in front of the tool box is a wench.
01-01-2019, 11:16 PM | #22 |
Aside from making sure your tow vehicle has the tow capacity and the trailer is rated to carry your AA truck, two things are important. First, make sure your trailer has brakes on both axles. Not all trailers with 3500 lb axles have brakes on both axles and my personal experience has told me you need the best possible braking capability. Second, get a trailer tongue scale to be sure you have the correct tongue weight, which is critical to avoiding a swaying condition which could cause you to lose control. Your tongue weight should be 10 - 15 percent of the total loaded trailer weight. Of course, make sure your trailers wheel bearings are freshly packed and your tires are in good condition and properly inflated.
01-02-2019, 07:59 PM | #23 |
Thanks everyone for the recommendations. At this time I don't think I will actively pursue a trailer but keep an eye out if one pops up. I poke with my father who has a trailer that would work if I needed to borrow one.
Regarding being in central IL, it isn't all cornfields with no big towns. I love 10 min from a sister town of 120k...surrounded by corn and bean fields. [emoji16] Sent from my Pixel XL using Tapatalk |
01-02-2019, 08:26 PM | #24 | |
As long as your trailer is nose heavy by a couple hundred pounds and you don't have an overslung condition it will tow fine.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
01-02-2019, 09:27 PM | #25 | |
No. I used to think what you are saying is correct, i.e., just have "some" tongue weight and make sure your trailer and tow vehicle are level. I found out the hard way that this is not the case, when a couple of years ago, I came close to having a serious accident while pulling my skidsteer on my 14K GVW trailer, when my gross weight was probably around 10K. It was a horrible experience. After that, I did some research and everywhere I looked I got the same answer: 10 - 15% of the gross trailer weight should be on the tongue. Some places recommended a weight distributing hitch, to help out. Also, I bought a scale to measure my tongue weight, just to be sure. Here's what GMC says, which is the same as what everyone else who is authoritative says on the matter: https://www.gmc.com/gmc-life/trucks/...or-safe-towing But, you could go for years without a problem and ignore this advice, like I did. Now, I am a believer! |
01-02-2019, 11:46 PM | #26 |
01-03-2019, 12:17 AM | #27 | |
01-03-2019, 09:13 AM | #28 | |
Good point, Bill. Depending upon the weight of the trailer load, keeping the front wheels down could be an issue and maybe require a weight distributing hitch. But, we're talking about a Model A on the trailer here and, therefore, I doubt the necessary tongue weight to get into the 10 - 15% tongue weight area would be more than 500 lbs., which should not be a problem for a half-ton pickup. |
01-03-2019, 09:25 AM | #29 |
I see a winch, but not a wench.............. |
01-03-2019, 11:49 AM | #30 |
01-03-2019, 06:01 PM | #31 |
good on you 30.................
I was hoping for the former..............! |
