09-02-2021, 09:09 PM | #1 |
Accessories for 1936 Ford V8's
Accessory Pines Winterfront on 1936 Ford Roadster. |
09-02-2021, 10:43 PM | #2 |
Re: Accessories for 1936 Ford V8's
Why "Winterfront"? I see what has been called "Pines Trim", but don't see how it would help in the winter.
Not trying to be argumentive, just curious. |
09-03-2021, 06:39 AM | #3 |
Thanks for the clarification. The correct description is Accessory "Pines Trim", installed on a 1936 Ford Roadster. |
09-03-2021, 07:03 AM | #4 | |
That is not the Pines Winter Front, its JUST the Pines Trim kit!!! The winter front is a completely separate item!!!! There is one for sale here on the Barn right now but I do not have a photo of it!!! AND NOT sure IF it works in conjunction with the trim kit as it covers the whole front of the grill effectively blocking off air flow to the radiator. IT has a flap that can be opened to let some air in and regulate the flow!!!! |
09-03-2021, 07:14 AM | #5 |
Here you go Tubman
09-03-2021, 05:11 PM | #6 |
This is the correct "Pines Winterfront" for the 1936 Fords, as added by "rockfla". Thanks for the clarification. |
09-03-2021, 05:14 PM | #7 |
I'm sorry to possibly offend, but that trim is just plain ugly.
The '36 grille is of a beautiful design. Trying to improve upon that, well, it ain't happening.
09-03-2021, 05:36 PM | #8 |
Judging from the other add-ons on that yellow roadster, the owner likes 'bling'. To each his own.
09-03-2021, 07:23 PM | #9 |
Pines Winterfront on slightly modified 1936 Ford - Closed and Open. |
09-03-2021, 08:02 PM | #10 |
Slightly?
09-03-2021, 08:09 PM | #11 |
Not the adjective I would use either.
09-03-2021, 08:26 PM | #12 |
Canadian 1936 Ford Roadster with a Pines Winterfront Accessory. |
09-03-2021, 10:23 PM | #13 |
How many factory options for 36 My 36 4 dr.conv.sedan has 4 glove box clock,radio,spyder hubcaps,bango st.wheel. no columbia r.e.
09-03-2021, 10:30 PM | #14 |
It's a fine line between sleek and silly. Only a few will know, but you might recognize it when you see it.
09-03-2021, 11:46 PM | #15 |
Accessory Ash Tray Radio and Glove Box Clock in open 1936 Ford. |
09-03-2021, 11:48 PM | #16 |
Nicely done. The hanging gauges seem out of place. But that might just be the mounting system. I'd ditch the the shifter ball, Just an opinion and that is all it is.
Love the faux wood dash painting. |
09-03-2021, 11:59 PM | #17 |
Lot of ways to customize the grill and not look like a rear spoiler on a civic. Its a 35 but
09-04-2021, 12:14 AM | #18 |
Still one of my fav 36 coupes granted it is a 3w and has an advantage. Wasn't a fan of the red grill.
https://kustomrama.com/wiki/The_Pier...s%27_1936_Ford |
09-04-2021, 12:25 AM | #19 |
Accessory Banyo Steering Wheel, Ash Tray Radio and Glove Box Clock in closed 1936 Ford. |
09-04-2021, 12:44 AM | #20 |
Accessory 1936 Ford Spyder Hubcap. They look great. |
