Hundreds of lbs of early Ford V-8 parts; 99.99% of these are NOS, some still with Ford tags or in original boxes. I have pics of the stuff that I will attach to this post. There is too much to pack and ship; come pick it up and pay with cash. Nearly all of the stuff is transmission, engine, generator, oil pump, engine bearings for both mains and rods, etc. There are 11 cluster gears, 20 intermediate gears, 5 imput shafts, 8 main shafts with six and sixteen splines. several sector gears, several oil pump pickup shafts with gears, brake parts, 4 drag links, lower engine mounts (one NOS pair and several used), generator parts to include several pulleys, thrust bearings, shifter forks, synchro rings, other gears like reverse. Lots of bearings and bearing races in original boxes. You pickup; asking $1250 for the lot. The stuff is located in the Springfield area of Massachusetts. Having a problem uploading the pics; send me an e-mail to
[email protected] and I will send you what I have.
