Old 03-02-2022, 10:13 AM   #1
mccsix
mccsix's Avatar
Default Electrical wiring diagram
I'm 85 and still cranking on my A.
Recently ordered a wiring diagram from Synders. Its colored coded and based on a 6v pos grd,
So my 12v neg system needs a lot of adjust to the diagram to get the car to run right and not burn itself to the ground..already had fire in the wiring after ammeter posts insulation failed.
So I have emailed out to Synders, Mikes and Bert's asking for input on changes to the diagram in consideration of volt/ground differences. I've gotten back good info and I think I've made all the necessary adjustments.
Today I'm powering up all the adjusted wiring I've installed and am confident/fearful of the smoke/no smoke results. I wish I had some of you veterans nearby to give the car a once-over.
Wish me luck.
Gene
USN
mccsix is offline   Reply With Quote
Old 03-02-2022, 10:35 AM   #2
Badpuppy
Default Re: Electrical wiring diagram
Not a lot to it, really. To change polarity, swap posts on battery, ammeter and ignition coil; repolarize generator.
To change voltage, change battery, coil, lights, horn, wiper motor, cutout.
Old 03-02-2022, 10:55 AM   #3
Patrick L.
Patrick L.'s Avatar
12v neg grd. I'll assume you have an alternator. But that doesn't make much difference. You should not have burnt anything.
Its not hard to switch to 12v neg ground.
The ammeter leads should not have burnt. It sounds as though they were grounded, loose, or, an aftermarket meter.
There are wiring diagrams readily available right here.
Old 03-02-2022, 11:34 AM   #4
mccsix
mccsix's Avatar
FYI the wires from alt to J box burned up and the ammeter needle is welded to it's case.
Gene
USN
Old 03-02-2022, 01:27 PM   #5
Patrick L.
Patrick L.'s Avatar
Sounds like something that should have been insulated wasn't.
Old 03-03-2022, 12:20 PM   #6
mccsix
mccsix's Avatar
I believe the small black insulators around the ammeter posts harden over time and the post contacted the case.
Gene
USN
Old 03-03-2022, 02:20 PM   #7
Doug Linden
Doug Linden's Avatar
There are other Model A owners in Pensacola, maybe they can give you a helping hand.
Doug Linden is offline   Reply With Quote
