Old 03-20-2020, 04:56 PM   #21
Synchro909
Synchro909's Avatar
Default Re: Overheating
Originally Posted by johnbuckley View Post
Hmm, not convinced, an extension of the "slower-circulation-permitting-better cooling" theory would be constricted hoses, and blocked rad tubes would improve cooling. Sounds dubious to me.
Sounds counterintuitive to me too. IMO, the only reason an engine overheats (assuming timing and mixture is right) is that the radiator is not up to the job. Start there.
This is a problem that often comes up on this forum and I understand why. Replacing a radiator is expensive so we try to find a solution that is not so hard on the hip pocket. Fix it right, fix it once.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 03-20-2020, 08:09 PM   #22
eagle
eagle's Avatar
When it comes to straight transfer of heat to the radiator then to the air, fast flow with lots of turbulence will transfer the most heat. However, putting a thermostat in the top hose will reduce the flow, causing a slightly higher pressure in the block, (actually less negative pressure) so the coolant won't flash to steam as soon. When even a very small amount of coolant flashes to steam it increases in volume I think about 1700 times, causing at least a dump out of the overflow, and sometimes the tea kettle effect. Granted, the radiator is likely on the edge of being too restricted for efficient cooling if the thermostat makes a difference but sometimes even a small difference gets you by for a while.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 03-20-2020, 09:35 PM   #23
Synchro909
Synchro909's Avatar
Eggzacly
Old 03-21-2020, 08:55 AM   #24
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Eagle, Right On
Jacksonlll is offline   Reply With Quote
Old 03-27-2020, 10:31 AM   #25
Licensed to kill
Licensed to kill's Avatar
I haven't had a chance to check out the calling system yet. I blew my knee out on the weekend and am laid up for awhile. I will, report back once I get a chance to check it out. Thanks everyone for the input.
Licensed to kill is offline   Reply With Quote
