Old 09-21-2018, 09:30 PM   #1
hb32
hb32's Avatar
Default 32 pickup commercial pedal plates
Trying to wrap my head around how these plates fit together. I have an original top plate but no bottom or insulation piece. I have figured out where the top one goes and have pics of the bottom so in the process of making a reasonable facsimile. Searched the barn and could only find pics of a passenger application. Looks like a simple piece of flat material and wondering if anyone has dimensions as well as a pic of it installed ? Is it nailed to the bottom of the floor board ?
As always, thanks to all that contribute.
hb32 is offline   Reply With Quote
Old 09-22-2018, 06:23 AM   #2
DavidG
DavidG's Avatar
Default Re: 32 pickup commercial pedal plates
Below are three drawings from the Early Ford V8 Club's "The 1932 Ford Book...." of the late commercial/truck pedal plates and foam rubber insulator that goes in between the two plates.
The holes in the upper right and lower left corners of the plates line up with one another and to the holes in the firewall with clinch nuts for their attachment. The lower plate is also nailed to the #1 wood floorboard via the three 3/32" along the bottom edge to facilitate installation of the floorboard with the lower pedal plate attached.
The early version of the plates and insulator differ only to the extent that the opening for the brake pedal lines up with the opening for the clutch pedal and not below it as in the drawings. Also, there was no hole in the early plates and insulator for the foot-operated starter switch push rod.
Old 09-22-2018, 08:40 AM   #3
hb32
hb32's Avatar
Thank you David and need to get this book.
Old 09-22-2018, 12:20 PM   #4
DavidG
DavidG's Avatar
You'll very likely find it worthwhile.
Old 09-23-2018, 07:17 PM   #5
jim1932
jim1932's Avatar
definately get the two volume book. been a great resource.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 09-27-2018, 07:22 AM   #6
vulture
vulture's Avatar
I recommend getting the books as well , so much information and details to help your build
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
