Old 05-11-2016, 08:16 AM   #1
ricklove
ricklove's Avatar
Default Package shelf removal 48 Ford Sedan
How do I remove the rear package shelf on my 48 Ford Tudor Sedan? Many thanks!!!!
ricklove is offline   Reply With Quote
Old 05-11-2016, 11:47 AM   #2
waterboychuck
waterboychuck's Avatar
Default Re: Package shelf removal 48 Ford Sedan
You will have to remove the back of the rear seat. Mine is out and in my basement so I took a photo. It's upside down so you can see the two black pieces and that section screws onto the solid wood piece that is darker in color in the photo. you should be able to see just by looking behind the seat. I hope this helps.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 05-11-2016, 01:33 PM   #3
ricklove
ricklove's Avatar
Many thanks!!!!! I assumed that I'd have to remove the lower and upper sections of the rear seat, but wanted to make sure before I did again. Had front seat and both rear sections out last month, but didn't think to check for the package shelf removal at the time. Again, thanks!
Old 05-11-2016, 05:19 PM   #4
waterboychuck
My car is totally striped down this time, like you see in my avatar, so I can give you photos of what the back section looks like if you want.
Old 05-11-2016, 09:02 PM   #5
FLA48
FLA48's Avatar
You will have to remove the bottom seat cushion to remove the seat back. It is bolted in place at the bottom.
FLA48 is offline   Reply With Quote
