05-26-2023, 08:43 PM | #1 |
Hardened Exhaust Seats
My '31 Pickup has a fully built touring engine with hardened exhaust seats. I'm now rebuilding my wife's '30 Coupe which will not be a touring car but rather just used for short trips. Are hardened exhaust seats necessary?
Thanks, Dave |
05-26-2023, 09:42 PM | #2 |
Re: Hardened Exhaust Seats
It sounds like the Coupe won't be doing many miles and what it does will be at low speeds. I wouldn't bother.
Henry didn't use them and there were thousands of Model As criss-crossing the country. The engine I use for long trips (up to 12,000 miles) does not have hardened seats
05-27-2023, 06:16 AM | #3 |
If you do not use the hardened seats, keep an eye on the valve clearances as they can change as the seat wears. A friend found one exhaust valve with only 0.002 clearance, but this is an extreme case.
05-27-2023, 10:18 AM | #4 |
It depends on how much the seats were previously ground , the seating area can be too wide and the valve can be sitting too low , some engines should have all the seats replaced
05-27-2023, 07:07 PM | #5 |
