Old 09-12-2021, 05:45 PM   #21
glennpm
glennpm's Avatar
Default Re: red liquid fuel gauge?
I’ve bought from them several years ago but when I checked this year, I couldn’t find it on their site which was easily located when I bought it before.
Old 09-12-2021, 08:37 PM   #22
Ian NZ
Ian NZ's Avatar
The original Ford red fluid has come up on Ebay now and again and it is the same fluid that is used in the Temperature gauge. I wonder if the gauge would still work if you fitted a little red ball.
Ian NZ is offline   Reply With Quote
Old 09-12-2021, 11:26 PM   #23
Brian
Brian's Avatar
'I wonder if the gauge would still work if you fitted a little red ball'
in order for the liquid in the sightglass to show true level in gastank, it MUST have a sg of 2.95
Old 09-13-2021, 06:11 AM   #24
glennpm
glennpm's Avatar
Good idea Brian. A small glass bead would work, not sure about plastics.
Glenn
Old 09-17-2021, 09:49 AM   #25
highbeams
highbeams's Avatar
Glenn
Glennpm: Do you know the inside diameter of the '33 glass fuel gauge?
Thank you - highbeams
highbeams is offline   Reply With Quote
Old 09-17-2021, 10:03 AM   #26
highbeams
highbeams's Avatar
"this substance is unfortunately illegal to ship for obvious reasons."
Deuce Roadster:
Would you please clarify your comment regarding the reasons as you factually acknowledge them.
Thank you in advance.
highbeams
Old 09-17-2021, 10:09 AM   #27
highbeams
highbeams's Avatar
Thank you very much for your idea regarding a ball to be used in the gas gauge glass tube.
Are you suggesting an exact diameter? Obviously; correct? Would you update your findings, please?
Thank you in advance -highbeams
Old 09-17-2021, 02:17 PM   #28
Brian
Brian's Avatar
The ball wasn't my idea, I was simply responding to Ian's post #22
Old 09-18-2021, 03:08 PM   #29
highbeams
highbeams's Avatar
Brian -
Do you have a '33 glass fuel tube handy out of a car to measure the inside diameter?
Thank you -
highbeams
Old 09-18-2021, 03:17 PM   #30
highbeams
highbeams's Avatar
Ian NZ-
Do you know the inside diameter of the glass fuel gauge?
thank you -
highbeams
Old 09-18-2021, 04:37 PM   #31
glennpm
glennpm's Avatar
"Do you know the inside diameter of the glass fuel gauge?"
I just measured the ID on an old broken gauge I have and then checked it with a drill bit. ID is 9/64"
Glenn
Old 09-18-2021, 05:25 PM   #32
glennpm
glennpm's Avatar
I would use a bead of 1/8" OD.
This is just an example since I doubt the Coral would withstand the acid.
https://www.michaels.com/bead-galler.../10120972.html
Last edited by glennpm; 09-18-2021 at 06:37 PM. Reason: Make clear that I’m not suggesting that coral is appropriate
Old 09-18-2021, 07:28 PM   #33
highbeams
highbeams's Avatar
Thank you much, Glenn.
I was under the impression that the ball to be used, as opposed to the 'red';
re your comment "I doubt the coral would withstand the acid."
Thank you, Sir.
highbeams.
Old 09-18-2021, 07:40 PM   #34
highbeams
highbeams's Avatar
Glenn
Thanks so much, Glenn!
Sincerely appreciated.
So, hopefully, the hydrastatic pressure will coincide w/the fuel level in the tank and push the 9/64" glass ball to the accurate position. THAT WOULD BE SPLENDID! As opposed to diddling with the 'red'. Correct me if I am misunderstanding. I've been known to uh, misunderstand, particularly with a honeydo.
https://thefractioncalculator.com/
2:04 PM
Pat Malone
Old 09-18-2021, 09:22 PM   #35
tubman
tubman's Avatar
What's the specific gravity of glass? I hope it's less than 2.95 or else it will sink to the bottom of the gauge.
Old 09-19-2021, 06:28 AM   #36
glennpm
glennpm's Avatar
Yes, good question and I checked it the other day.
Glass beads 2.5 SG
https://www.engineeringtoolbox.com/s...als-d_293.html
Old 09-19-2021, 04:46 PM   #37
Ian NZ
Ian NZ's Avatar
It would be easy to test the ball just put it into some of that fluid in a phial and see if it sinks.
Old 09-19-2021, 06:45 PM   #38
highbeams
highbeams's Avatar
Here is the msds on tetra-bromo-ethane
https://www.cdhfinechemical.com/imag...9-27-6MSDS.pdf
Brian:
Thanks so much for that.
Pat Malone
Old 09-19-2021, 08:19 PM   #39
highbeams
highbeams's Avatar
The 'red' is too toxic for me.
The glass-ball idea is the best. re: https://www.jansjewels.com/3.5mm-No-...ds_p_3583.html
glass tube i.d. is 9/64" or 3.571 mm.
Old 09-19-2021, 08:23 PM   #40
highbeams
highbeams's Avatar
