03-20-2014, 08:11 PM | #1 |
Erratic spark
Drove the 31 today but when I got home it wouldn't start. Cranked and cranked...no luck. Pulled coil wire and found I only had spark when I first hit the starter button and at the moment I let off the starter button. Got to looking around. One of the leads in the terminal box looks like it melted the plastic back of the terminal box. Terminal box got hot due to excessive cranking, I would guess???? The wires in the terminal box sure don't look like they are in the best shape. Would this cause the bizarre spark issue or would it just be a symptom of another issue?
03-20-2014, 08:22 PM | #2 |
Re: Erratic spark
The terminal box should not be getting hot, it has nothing to do with the starter. If it is hot and melting it has a problem and needs to be fixed before it gets worse.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
03-20-2014, 08:22 PM | #3 |
Re: Erratic spark
Starter current does not pass through the terminal box.
Original terminal boxes are bakelite (phenolic thermoset) and do not melt, you must have an aftermarket box. Those are known for shorting through the backside to the firewall. I would remove the terminal box from the firewall and replace it. Make sure the screws of the replacement are not exposed on the backside to the firewall. Some people fill in the recess with the exposed screws on the back of aftermarket boxes with epoxy, like JB, or place an insulating sheet behind it. Check security of all the connections behind the dash panel and at the coil while you're at it. |
03-20-2014, 08:28 PM | #4 |
Re: Erratic spark
keep your battery disconnected till you fix it
03-21-2014, 09:24 AM | #5 |
Re: Erratic spark
Sounds as if the terminal box connections are loose or corroded. Also as '30 mentioned there have been some instances of the bolts contacting the fuel tank and grounding.
03-21-2014, 09:26 AM | #6 |
Re: Erratic spark
that happend to me once tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information [email protected] |
03-21-2014, 10:33 AM | #7 |
Re: Erratic spark
Mike K hit the nail on the head on post #4. I would figure on replacing both wiring harnesses and the terminal box. If you cant find a good used original terminal box, I would be sure and fill the recess behind the terminal box screws with two part epoxy.
03-21-2014, 02:05 PM | #8 | |
Re: Erratic spark
