10-19-2014, 07:02 PM | #1 |
early ford juice brakes
Someone prior to my ownership put 40 brakes on my 33 coupe, the problem is after installing a new master cylinder and bleeding the system, fluid leaks from the vent hole in the cap (squirts from it) after pumping pedal. (looking back I think the old master cyl was probably ok cuz it was doing the same thing which is why I replaced it) Stock pedals in place putting cylinder in floor, maybe too low, below wheel cyls? (check valve) Anyone run into this before?
10-19-2014, 07:09 PM | #2 |
Re: early ford juice brakes
Two items come to mind, air in system or more likely brakes need adjustment. Pete
10-19-2014, 10:56 PM | #3 |
My guess is air in system. Air gets compressed and upon pedal release the air decompresses and forces the fluid back to the cylinder with such force that it can not be contained in the reservoir.
10-19-2014, 11:16 PM | #4 |
On my Pontiac, if the level of the fulid is to high, it will come out the vent, but stops after it gets a litter lower. When the piston moves forward it has to move past a port, untill it does it shoots fluid back into the reservoir, and that's when it came out the vent on mine.
10-20-2014, 10:19 AM | #5 |
Did you bench bleed the master cylinder?
10-20-2014, 12:09 PM | #6 |
10-20-2014, 12:14 PM | #7 |
The fluid should be down about 1/4 to 1/2 inch below the cap. Are you filling it all the way to the top?
10-20-2014, 12:17 PM | #8 |
I'm with Bader, the only problems of this nature I've had is when the master cylinder wasn't bench bled.
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
10-20-2014, 01:46 PM | #9 |
It is perfectly normal for fluid to squirt when initial movement of the piston causes the compensating port to be closed off, trapping fluid in the cylinder. All masters I have ever had any experience with have an expanding gasket that completely seals off the fluid from the air vent, and would prevent any fluid loss through the vent. Didn't the Lockheeds also have a similar gasket? If not, they should.
10-20-2014, 06:11 PM | #10 | |
10-20-2014, 08:03 PM | #11 |
DONT bench bleed single circuit master cyls..
You really need to put a brick or piece of wood behind the pedal to prevent it going too far.
