Old 03-03-2021, 03:37 PM   #1
ochnemowitz
Default changing oil on 39 for flathead?
changing oil in 39 ford flathead?
ochnemowitz is offline   Reply With Quote
Old 03-03-2021, 03:38 PM   #2
ochnemowitz
Default Re: changing oil on 39 for flathead?
Changing oil on a 39 ford flathead, where do you get filters for these?
Old 03-03-2021, 03:51 PM   #3
Will D
Will D's Avatar
Can you post a picture? What type of filter setup do you have?
If it's a typical bypass canister type, C4 Fram or WIX 51006 should fit. Napa carries the WIX. Best to pull what you have and post a pic of the filter or at least the housing.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 03-03-2021, 04:27 PM   #4
adileo
adileo's Avatar
Ya pic would help. 39 doesn’t have a filter.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 03-03-2021, 06:20 PM   #5
Merc Cruzer
Merc Cruzer's Avatar
First picture is Wix, second picture is Fram.
I am a Wix man myself.
The third picture is the Wix filter I pulled out of my engine 11 years ago, after I bought the car.
Merc Cruzer is offline   Reply With Quote
Old 03-03-2021, 06:31 PM   #6
miniceptor86
miniceptor86's Avatar
Nasty!
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 03-03-2021, 06:57 PM   #7
Will D
Will D's Avatar
Nice thing about the wix is it comes with x2 different size large o-ring lid seals depending on the canister you have. The fram c4 comes with one size if your lucky. Fram C4P comes with x2 seals but the filter is slightly different dimensions, shorter in height if I remember correctly but will still work.
I like the full metal housing of the wix compared to the fram but the fram is easier to cut open for inspection if needed.
Old 03-03-2021, 07:38 PM   #8
30-9
I agree with post 3 & 4 for a pic. I have a friend who has this:
File Type: jpg D5D84AF7-1C0B-4D78-9D09-9F0571AF0FDB.jpg (20.1 KB, 36 views)
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 03-03-2021, 07:50 PM   #9
TJ
TJ's Avatar
There's a video on You Tube where a guy compares the various brands of spin on filters. If you watch it you will avoid Fram filters.
Old 03-04-2021, 03:30 PM   #10
Automotive Stud
Automotive Stud's Avatar
I mean, I guess for a driver it's okay. But damn that's ugly.
Automotive Stud is offline   Reply With Quote
