09-13-2017, 03:34 AM | #1 |
engine flush
The trailer queen I'm working had fairly clear oil. After several laps around the block the oil is very dark. Engine has had 500 miles in the last 20 years. No oil filter. I've heard several options for flushing. suggestions, please. I don't like the idea of a kerosene flush due to the low viscosity of the kero.
09-13-2017, 05:22 AM | #2 |
Re: engine flush
You probably don't want to hear this, but forget the flush. Pull the pan and clean it out.
09-13-2017, 05:38 AM | #3 |
Re: engine flush
I agree. There was a thread (either here or on the H.A.M.B.) a few weeks ago that made a pretty good case against engine flushing.
09-13-2017, 05:59 AM | #4 |
Re: engine flush
That the engineoil gets dark means it´s doing the job...
If it was my car and it ran fine...i would just make sure it would go for some longer trips from time to time, change the oil frequently and drive it... Starting to poke around in an engine without oilfilter means you have to get it real clean or anything loose will be in the oilflow which can cause more issues then it solved... |
09-13-2017, 07:24 AM | #5 |
Re: engine flush
Do a leakdown test of the cylinders and you'll likely find that the oil is black from blow-by...
IE - Exhaust soot and unspent fuel. I would change the oil and run the engine through a break-in cycle or two and see if the blow-by gets any better. It may take many miles to get those rings friendly with the cylinders, if they ever do... Many builders used chrome faced rings back in the day - thinking they were using the best. And they were. However, chrome rings required the cylinder bores to be perfectly round and if you just honed out an egg shaped standard cylinder - well - you would likely never get a perfect seal.
Regards - Randy 1933 Tudor |
09-13-2017, 04:24 PM | #6 |
Re: engine flush
09-13-2017, 06:33 PM | #7 |
Re: engine flush
The engine really needs/needed to be run under a load to seat the rings. If the break in was not done correctly it may be difficult to ever get them to seat properly.
