Old 05-11-2021, 07:00 AM   #1
oldredford
Default Model A coupe value
What is the fair market value of a 1930 5 window coupe in good condition. Needs paint uphostery.
oldredford is offline   Reply With Quote
Old 05-11-2021, 07:03 AM   #2
McMimmcs
McMimmcs's Avatar
Default Re: Model A coupe value
Do you have any photographs ?
Old 05-11-2021, 07:14 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I guess I don't understand. How can a car be in "good condition" yet need Paint and Upholstery?
If you break down the value of a car by 3 major areas (Mechanical, Paint, & Trim) it would seem you are lacking in 2 major areas. Without seeing it as Wayne suggested, I will pitch a F/M value number of $3k - $5k. Naturally that number can go either way upon visual inspection.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-11-2021, 07:21 AM   #4
oldredford
The car has lacquer paint and uphostery attacked by moths. Mechanically it is in good condition. A turn key minus paint and uphostery. Don't know what path to take.
Old 05-11-2021, 07:47 AM   #5
BRENT in 10-uh-C
To some folks, the paint won't be an issue. To others, that is a red flag.
Lacquer paint is not the issue. I can show you many original cars that were painted with lacquer at the factory and years later the paint still looks great and without any cracks or checking. If lacquer paint cracks, there are other issues underneath.
As far as what path to take, it depends on what your goals are. The vehicle likely has severe diminished value due to the paint and upholstery, however I doubt you would be able to recover your investment of new paint and upholstery if you were to do those prior to selling.
BRENT in 10-uh-C
Old 05-11-2021, 08:34 AM   #6
ronn
5-6k together
chassis is 2500 and body is 4000.
Old 05-11-2021, 06:09 PM   #7
WHN
Does it have an asking price?
Old 05-11-2021, 06:28 PM   #8
nkaminar
nkaminar's Avatar
There are so many variables. The car could be worth anywhere from $3,000 to $16,000 depending on what has been done to the engine (insert bearings, balanced crank, pressure oil, cam, valves, high compression head), transmission (Mitchell syncro), overdrive, rear end rebuilt, new tires, power coated wheels, rebuilt brakes, etc. To get an estimate of the value you will have to post photos and ca ompletely describe the car.
