Old 06-29-2020, 06:46 AM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default The T-Bird was in a rain storm yesterday
The wipers work super. I was surprise on how well they worked. Don't need electric wipers. MMO did the trick.
Old Redneck is offline   Reply With Quote
Old 06-29-2020, 03:38 PM   #2
JimNNN
Default Re: The T-Bird was in a rain storm yesterday
Glad they worked for you Old Redneck. Where exactly did you apply the Marvel Mystery Oil? I used the wipers on my early 60's Mercury last week, and wasn't impressed with the performance. It was the very last of the vacuum wiper cars. I think MMO might help me. I need new blades, too.
JimNNN is offline   Reply With Quote
Old 06-29-2020, 03:38 PM   #3
Ole Don
Ole Don's Avatar
I have no idea what the prior owner did to the vacuum wipers in my 55 sedan, but the only time they didn't work was in fifth gear at full throttle at over 6000 feet in the rockies. And the 312 had an Iskenderian cam, the highest vacuum was 11 inches!.
Ole Don is offline   Reply With Quote
Old 06-29-2020, 05:17 PM   #4
runewilliam_merc
JimNNN
In the service manual for mye 1952 Mercury, it states that once a year I should lube the wiper motor:
1: disconnect vacuum hose and put ut in a container with motor oil.
2: turn the wiper switch fully on.
3: manually drag the wiper until it ALMOST reaches the point where it will return
4: manually return wiper to start position.
This will make the wiper motor suck oil into itself and soften the leather seal around the piston.
Rune Waltoft from Norway
Sent fra min S52 via Tapatalk
runewilliam_merc is offline   Reply With Quote
Old 06-29-2020, 06:05 PM   #5
Old Redneck
I disconnect the hose at the wiper motor. I squart a few drops of mmo in and use just 5 pounds of air pressure then works the wipers by hand several times. Then install the vacuum hose start the motor and watch the wipers. Should spray water on the windshield. I have done this on several of my early fords that work very well. Make sure the air pressure is no more then 5 pounds. MMO is Marvel Mystery Oil. Some use brake fluid, I was afraid to.
File Type: jpg 6D74D903-E223-4708-9F2C-C5AE95D46B7D.jpg (67.5 KB, 155 views)
Old 06-29-2020, 09:59 PM   #6
40cpe
40cpe's Avatar
Ken, are those power lines going over your house?
40cpe is offline   Reply With Quote
Old 06-29-2020, 11:17 PM   #7
Daves55Sedan
Daves55Sedan's Avatar
Hate to admit I'm becoming a little neglectful in old age, but I haven't lubed my vacuum wiper motor in at least 20 years, but it still works like new and gets plenty of use. Hadn't done a complete grease job either in about 3 years. That's bad. shame on me.
Daves55Sedan is offline   Reply With Quote
Old 06-30-2020, 07:16 AM   #8
Old Redneck
NO they are not going over my house.
Old 06-30-2020, 08:42 AM   #9
40cpe
40cpe's Avatar
That's good. Sometimes cameras don't show the true setting.
Old 06-30-2020, 10:58 AM   #10
58Yeoman
58Yeoman's Avatar
Maybe that's not his house.
58Yeoman is offline   Reply With Quote
Old 06-30-2020, 11:13 AM   #11
Old Redneck
It is where I hang my Hat.Move there in 1972. The house next to mine is mine also.
Old 06-30-2020, 07:35 PM   #12
paul2748
paul2748's Avatar
The red on your Bird looks like the 55 or 57 red, not the Fiesta Red (reddish orange or orangish/red) of a 56 ??
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-01-2020, 07:48 AM   #13
Old Redneck
The Paint is 1980 Ford ZF Bright Red Color Number 98p-5330 Tec Base Martin Senior. The top was white when I got the car. I change it to Red. I like the car the way it is. This winter I am going to repaint the whole car.
Old 07-02-2020, 12:33 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Well then....what are those three long, skinny black things that are going through the sky, but are NOT REALLY over that house that they just LOOK LIKE they're going over? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-02-2020, 02:54 PM   #15
Old Redneck
You made me o outside and look. The wires do not go over my house. They stay along the curb going up pass the house. The picture fools you and me.
File Type: jpg C9F9991B-F1A5-4897-B8F0-5A8E01DD67AE.jpg (61.6 KB, 27 views)
Old 07-06-2020, 01:07 PM   #16
JimNNN
Originally Posted by runewilliam_merc View Post
JimNNN
Old Redneck I disconnect the hose at the wiper motor. I squart a few drops of mmo in and use just 5 pounds of air pressure then works the wipers by hand several times. Then install the vacuum hose start the motor and watch the wipers. Should spray water on the windshield. I have done this on several of my early fords that work very well. Make sure the air pressure is no more then 5 pounds. MMO is Marvel Mystery Oil. Some use brake fluid, I was afraid to.
Thanks very much for the instructions runewilliam_merc and Old Redneck. I'll try that on my '61 Mercury. My problem is that I never intentionally drive it in the rain, so the vacuum wipers get a little ignored. Probably the only part of the car that does . I'll replace the blades while I'm at it.
Old 07-06-2020, 06:25 PM   #17
Old Redneck
JImNNN show us some pictures of over there. The internet has made the world smaller which is great for all us. We will show you pictures over here if you want.
Old 07-06-2020, 08:08 PM   #18
paul2748
paul2748's Avatar
Nice looking vehicles
48 Ford Conv
56 Tbird
54 Ford Victoria
