06-18-2020, 10:35 AM | #1 |
brake adjuster dust cover problem
Hi Guys; i am having a problem removing the brake adjusting dust cover on my 35 ford.
Some one in another life installed brake energizers that does not the screw adjuster ,but has a wheel inside.i am installing Teds energizers. The cap is peened down to hold the dust cap. I know if I still had the stock adjuster i can screw it in and pop the cover off. I am not having any luck putting the peened area back to pop the cover off .Any ideas?? |
06-18-2020, 10:49 AM | #2 |
Re: brake adjuster dust cover problem
If you can get a replacement dust cover, maybe weld something onto the dust cover and use a slide hammer to pop it off?
06-18-2020, 03:26 PM | #3 |
Use a small punch or a sharp screw driver and punch one side of it on a angle and collapse it ,reshape it later by using a ball peen and a socket as a anvil ,grind the edges to refit it ,
06-18-2020, 04:35 PM | #4 |
06-19-2020, 06:21 AM | #5 |
Thanks for your quick reply Ted. I need to purchase the proper adjusting rods for 4 wheels can you supply them?
06-19-2020, 02:55 PM | #6 |
Thread Tools | |
Display Modes | |
