Old 04-01-2020, 04:25 PM   #1
moonraker
moonraker's Avatar
Default What lube for '39 vacuum wiper motor?
I need to lubricate a wiper motor. It starts to make squeaky noises after operating for a few minutes. What should I use?
moonraker is offline   Reply With Quote
Old 04-01-2020, 04:39 PM   #2
petehoovie
petehoovie's Avatar
Default Re: What lube for '39 vacuum wiper motor?
In my '53, I removed the rubber vacuum hose from the base of the carb and shot some GIBBS Oil into it. The wiper motor freed up instantly and operated like new....It's best to use the long plastic applicator tube supplied with the GIBBS Oil when doing this.
Old 04-02-2020, 10:05 AM   #3
JayChicago
JayChicago's Avatar
I have read others saying just use any light weight oil. My ‘40 came to me with wipers frozen and I had same success as mentioned above. I pulled the motor(not difficult on a ‘40), a few drops of 3-in-1 light oil into the vacuum port, freed up instantly, now works like new.
Old 04-02-2020, 10:16 AM   #4
moonraker
moonraker's Avatar
Thanks for answers! Gibbs oil is not available in Russia. Is WD40 a substitute?
Old 04-02-2020, 10:21 AM   #5
KGS
KGS's Avatar
WD 40 isn't really a good lubricant. I've used Marvel Mystery oil which works OK but may not be available to you either. A very light oil such as 3&1 oil or sewing machine oil will do the job.
Ken
KGS is offline   Reply With Quote
Old 04-02-2020, 10:26 AM   #6
A bones
A bones's Avatar
It will get it loose. The complaint with WD40 is it disappears. It design was for removing moisture. Any light weight oil should give a happy result.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 04-02-2020, 10:48 AM   #7
glennpm
glennpm's Avatar
Hi Pete,
I wondered about just pulling the hose as you did but didn’t think it would work since it drawing air away from the motor,i.e. vacuum line. In my 40 pulling the motor would not be easy.
glennpm is online now   Reply With Quote
Old 04-02-2020, 10:53 AM   #8
Merc Cruzer
Merc Cruzer's Avatar
Under what might be available to moonraker: I was thinking ATF, since it is a lite oil?
Merc Cruzer is offline   Reply With Quote
Old 04-02-2020, 11:11 AM   #9
flatheadmurre
flatheadmurre's Avatar
Sewing machine oil...must be available worldwide...thin and designed to lube..usually high quality and in a small container...
Old 04-02-2020, 11:12 AM   #10
moonraker
moonraker's Avatar
I can find sewing machine oil
Old 04-02-2020, 11:26 AM   #11
tubman
tubman's Avatar
Originally Posted by glennpm View Post
Hi Pete,
With the hose disconnected, operate the wiper blade manually. Moving it in one direction (I forget which) creates a vacuum on the inlet.
Old 04-02-2020, 03:44 PM   #12
glennpm
glennpm's Avatar
Thanks Tubman that makes good sense.
Glenn
Old 04-02-2020, 08:11 PM   #13
J Franklin
J Franklin's Avatar
Don't use WD-40 as it can cause pot metal to swell and ruin the wiper motor. light oil or open it up and use light grease.
Old 04-03-2020, 07:20 AM   #14
glennpm
glennpm's Avatar
I just found this great article on "Lubricating the Vacuum Wiper Motor". My motor is very stiff so I'll be just oiling using Marvel Mystery Oil, MMO, I know it is good for the leather in my Columbia vacuum canister so a good choice here.
I know that brake fluid and ATF will swell rubber and give a better seal. I'm not sure how it acts on leather which is used on the wiper motor internal paddle.
https://www.mafca.com/downloads/Tech...um%20Wiper.pdf
Glenn
Old 04-03-2020, 07:47 AM   #15
glennpm
glennpm's Avatar
... and a couple of patent office documents:
Old 04-03-2020, 10:53 AM   #16
petehoovie
petehoovie's Avatar
Here's how to lubricate the motor, which should be done three or four times a year: 1. Remove the vacuum hose at the wiper motor. Lightly hold your finger over the hose nipple on the motor and cycle the wiper blade back and forth.. Note that in one direction the motor sucks in air, and in the opposite direction, the motor expels air through the nipple. Place the wiper blade in the position such that the motor will begin to suck air at the nipple. 2. Attach a six‐inch long piece of hose to the motor nipple and hold the open end up. Using a squeeze bottle, force one teaspoonful of lubricant into the hose. Place a rag on the cowl below the wiper motor. Hold another rag over the open end of the hose. 3. Cycle the wiper blade back and forth several times. Repeat the process again, adding a second teaspoonful of lubricant. 4. Start the engine and run the wiper motor. It should run well. If it does not, the wiper motor should be disassembled, cleaned, inspected and a rebuilding kit installed. It is normal for the wiper to slow down when the car is accelerated, but it should not stop altogether.
[Editor Note: Using brake fluid as a lubricant is not recommended by Chuck Christensen, 2012 MAFCA Technical Director, as spilled brake fluid can damage the car's paint, either during the lubrication or afterward during wiper use. Instead, use a light machine oil.]
Old 04-03-2020, 10:55 AM   #17
redmodelt
redmodelt's Avatar
The instructions I have see say to use brake fluid.
Old 04-03-2020, 10:57 AM   #18
glennpm
glennpm's Avatar
Can you post the instructions you have please?
Old 04-03-2020, 11:07 AM   #19
petehoovie
petehoovie's Avatar
Old 04-03-2020, 11:23 AM   #20
tubman
tubman's Avatar
I used brake fluid in the wiper motor of my '51 and it helped a lot. Using a bit of care can prevent paint damage from the brake fluid.
