Old 11-27-2016, 10:43 PM   #1
silversink
silversink's Avatar
Default Magnito
are there articles on installing a mag in place of the dist. I have several 4 acyl. mages that could possibly be adapted to work
Hotrods don't have valve covers
silversink is offline   Reply With Quote
Old 11-27-2016, 11:37 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Magnito
Do you know the advance curves for these magnetos? Are these possibly tractor mags?
Remember, just because something can be made to fit, isn't a good reason to make it fit.
Stock ignition is so easy to fix and maintain, that I wouldn't change.
Old 11-28-2016, 04:44 AM   #3
Synchro909
Synchro909's Avatar
Default Re: Magnito
I know of a Model A with twin ignition. Points and coil for one and magneto for the other. It has an OHV head from the 30's and quite a competition history. For ordinary running, why would you bother. Like Tom said, the standard system is soooo simple and reliable.
Old 11-28-2016, 09:06 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Magnito
Most Mags put a tremendous load on the dist drive gear & shafts.
Bill Worry
"THE ASSISTANT GURU OF STUFF"
Old 11-28-2016, 01:00 PM   #5
George Miller
George Miller's Avatar
Default Re: Magnito
I use to change tractor magnetos to dist. and use a coil. Don't go there will not help your engine. But might give you a fit. Do you know how to set the trimming, with the impulse in the mag.
George Miller is offline   Reply With Quote
Old 11-28-2016, 01:33 PM   #6
40 Deluxe
Default Re: Magnito
Bill Worry
It does take some power to drive a mag but would it be more than what it takes to drive the oil pump with 20W-50 in the crankcase?
Old 11-28-2016, 02:04 PM   #7
BILL WILLIAMSON
Default Re: Magnito
YES!
Bill W.
