Old 04-14-2021, 05:03 PM   #1
drezin
Default 37 steering box
Installing a 37 steering box in a 35 coupe. when using the 35 mount which hole gets redrilled. the top slide hole or the bottom round hole? I have a 37 mount but think it be easier using the 35 mount with the car all together
drezin is offline   Reply With Quote
Old 04-14-2021, 05:14 PM   #2
Brian
Brian's Avatar
Default Re: 37 steering box
The top hole, you will notice the two bottom holes line up with the early mount, you'll need to drill a new top hole through ear on steering box and through the mount. Fit it all up and you'll see what you need to do.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 04-14-2021, 06:50 PM   #3
drezin
thankyou
