11-23-2016, 09:35 AM | #1 |
steering gear box questions
I got my steering box apart it was full of grease, i have done this before on my 37 ford pickup because of leaking into the light harness with mobil 1 synthetic grease and it actually steered much better. That said however i am putting a new needle housing on this gear box to eliminate the bushing since it has needle bearings and a seal the steering shaft is good and it was tight with the bushings so i see no issue does anybody do this and when you do can i just use the 600w or is grease better?
11-23-2016, 11:22 AM | #2 |
Re: steering gear box questions
Oil But there will be other views! They make a steering gear end plate but only for two tooth unit.,prevents oil from leaking.
www.whidbeymodelaclub.com Last edited by Gary WA; 11-23-2016 at 11:29 AM. |
11-23-2016, 11:49 AM | #3 |
I have always used the grease, but then it has been 50+ years since I rebuilt a steering box and I don't plan to do the one I have now, so if you can find a seal that will not allow oil to leak into the switch, hey, go for it. There have been great breakthroughs in seals in 50 years.
Bill, nice delivery.
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart |
11-23-2016, 12:00 PM | #4 |
did not know about the endplate
11-23-2016, 12:20 PM | #5 |
Here you go from Model a Venders. #4
www.whidbeymodelaclub.com |
11-23-2016, 12:54 PM | #6 |
11-23-2016, 02:46 PM | #7 |
"They make a steering gear end plate but only for two tooth unit.,prevents oil from leaking."
Part for 7 tooth box is 5030- Bratton's. 7 tooth steering shaft retainer with tube.
I noticed the harder I work the luckier I get! |
11-23-2016, 06:09 PM | #8 |
Penn-Rite steering box lube..................no leaky.
Paul in CT |
11-23-2016, 09:20 PM | #9 |
Mitch i got it and the box needs help the grease in it did not do it any favors.
11-23-2016, 09:25 PM | #10 |
FWIW, I haven't heard any favourable comments about the needle beraing conversion, only negative.
11-23-2016, 09:44 PM | #11 |
11-23-2016, 10:12 PM | #12 |
I rebuilt the 7-tooth steering box on our 1928 Tudor last winter. I could not find one of the clever oil retainer tubes to fit my particular setup. I did not want to use grease as that was what was in the box when I tore it down. A lot more rust than lubricant.
The seal I found at several vendors appears to be an ineffectual piece of felt. In its place I installed a rubber/fabric washer designed for a water tap stem. It has not lost a drip in several hundred miles of city driving. Unfortunately I cannot give any hint as to what make or model of tap as it came from a box of generic washers bought some thirty or more years ago. |
11-24-2016, 12:35 PM | #13 |
Oil not grease!
11-24-2016, 01:19 PM | #14 |
As flamingo said,,,,,penrite
http://www.restorationstuff.com/pdf/...plyCompany.pdf Scroll down to page 25 ,,,,,,LUB009 Steering box lube. That's all I use in 3 of mine. |
