10-10-2016, 05:53 AM | #1 |
new ignition switch wiring question
I bought one of the new expensive switches from snyder it is a 3 pole switch if i understand this switch correctly key turns left to one terminal center is off turn right to next terminal i assume center is off since key will come out of switch at that point since you have to turn the switch one way or the other how would you wire it and what good is the accessory side. Or what have some of you fellas done?
10-10-2016, 06:28 AM | #2 |
Re: new ignition switch wiring question
The second or ACCY position is for turning on a radio or an accy with the engine off. In this position there is no power going to the points..
SEE MY CORRECTION BELOW. Sorry Last edited by Mitch//pa; 10-10-2016 at 02:54 PM. |
10-10-2016, 11:07 AM | #3 |
Thanks Mitch that is kind of what i thought did not really know a good use for it but i will not put in a cb or radio or anything like that.
10-10-2016, 12:09 PM | #4 |
You do not want to take a very high amp draw off of that ACCY post or it could weaken your spark.
And if you use this style switch, you do NOT want to put it in the wire that runs from the coil (+) post (assuming positive ground -- connected to (-) if neg. ground) to the distributor points, as was done originally. Instead, you want to put this switch in the wire that supplies power from the terminal box to the coil's (-) post (assuming positive ground -- connects to (+) if neg. ground). Then you can also supply power to something else from the ACCY post. You could connect a "cigar lighter outlet" to the ACCY post to provide power for a cell phone or a GPS. They don't draw much current and will run on 6 volts. Just be sure to get the polarity correct. Then the GPS or phone charger would go off with the key.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
10-10-2016, 02:03 PM | #5 |
So if say a radio was connected to this accessory post, it would still receive power in the on position as well as the acc position?
10-10-2016, 02:07 PM | #6 |
else to the switch. Bob |
10-10-2016, 02:53 PM | #7 |
OKAY CORRECTION. The ACCY terminal has power when the car is running ... KOER
ACCY terminal will have power with the key turned to the left Sorry for the confusion & misinformation Last edited by Mitch//pa; 11-22-2016 at 01:54 PM. |
10-10-2016, 08:13 PM | #8 |
And remember, this switch is NOT designed to use with a stock ignition wiring system.
To use this switch, the system has to be re-wired as a HOT SWITCH system, like MOST cars run. It's easy to convert it to that kind of system. Bill W.
10-11-2016, 05:58 AM | #9 |
I will be running a fsi distributor model a type on this car.
11-22-2016, 11:29 AM | #10 |
Ok i am wiring this switch i am a little confused as to how to wire with the key in the middle position switch is off and i can remove the key if i turn it left to accy i get no continuity with any terminal just like in the off position if i turn it to the right ignition I have continuity on all three terminals so i do not get how to wire this switch so that accessory works when the key is to the left. I guess i do not see how this should work.
11-22-2016, 12:17 PM | #11 | |
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart Last edited by DaWizard; 11-22-2016 at 12:26 PM. |
11-22-2016, 01:27 PM | #12 |
It will be 12v neg ground bought this switch from brattons and it was made by nurex so i called them we got it figured out he told me to jiggle the key a little thought there might be a little something on a contact now it is working just like it should everytime.
