Old 10-21-2011, 07:22 AM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default B engine in a Model A for Turner
Turner, your e-mail wouldn't go through. call me 207-485-0707 Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 10-28-2011, 08:29 PM   #2
Turner
Default Re: B engine in a Model A for Turner
Walt, Do you know of anyone who makes "rigid" rear mount for installing the B engine? I've seen the float-a-motor kits, but I would prefer a rigid mount. Thanks for the reply. Lee Turner
Turner is offline   Reply With Quote
Old 10-28-2011, 08:47 PM   #3
Walt Dupont--Me.
If your going to use the Model A trans, you'll have to cut the flywheel cover off the B oil pan and use the A bell housing. Then you can use the A rear mounts. Walt
Old 10-31-2011, 06:47 PM   #4
Turner
Walt, I'm looking to use the B flywheel housing, B pan, and B trans. In your case, did you use the "float-a-motor" kit for the rear installation? I've seen that offered for the B flywheel housing. I'm looking for a rigid rear mount for the B flywheel housing. Lee
Old 10-31-2011, 07:26 PM   #5
Walt Dupont--Me.
Yes, I'm useing the float A motor rear mounts on the sides. BUT, if your useing the A float a motor kit, the 2 bolt hole on the B housing are off about 1/2in. for the A floaters. I used the bottom and the rubber donuts from the A kit and made the top one out of 1/4in. angel iron. Walt
