Old 08-22-2016, 01:15 PM   #1
coupe1942
coupe1942's Avatar
Default Speedometer cable clip placement on frame
I have a 1930 ccpu, 82-B, that I am trying to get back in order and on the road again. The previous owner did some questionable things, so I am trying to replace and revive much os what was done incorrectly, as best I can.
Forget about the positive battery cable which is long enough to stretch from London to Texas, as it has already been removed and will be replaced. Same with the battery box holder assembly.
My question is regarding those clips for holding the speedometer cable up and off of the muffler so that the grease inside of it is not burned and the cable is essentially free or clear of obstructions. Where are these clips normally attached on the frame or elsewhere so that the cable is protected and free from laying on top of the muffler as shown in these photos?
Waiting on a new wiring harness and other parts to get the ol' Gal up and on the road as a daily driver. I haven't seen any photos of the placement for these speedometer cable clips and wondered if it was simply up to the owner to put them where they wanted them or if there was really some specific location for them?
Thanks for any input or photos.
coupe1942 is offline   Reply With Quote
Old 08-22-2016, 01:33 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Speedometer cable clip placement on frame
From the shift lever go to the right top frame rail and you should see the mounting hole. I posted a picture once, but have very little luck in using the search.
Old 08-22-2016, 01:40 PM   #3
CarlG
CarlG's Avatar
In your last picture, just above the yellow arrow, there is a hole in the frame. That is where the clip goes.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-22-2016, 03:08 PM   #4
Tom Wesenberg
Here, I just took another picture of my bracket.
Old 08-22-2016, 04:39 PM   #5
coupe1942
coupe1942's Avatar
Thanks.
I went out and looked the frame over and located the exact hole for proper placement . I also found that the photos I had previously posted tricked the eye a bit, as that speedometer cable is not actually laying on top of the muffler at all as it appears, but is maybe a couple of inches above it.
There was a big grease globule at the frame where it was routed and I put my hand right into it as I ran my fingers down the cable near that mounting point. I'll have to check that out, as I had my speedometer refurbished and re-calibrated and I don't want to have cable issues when I reinstall it in the near future.
Again, thanks for all the input and photos.
Old 08-22-2016, 04:55 PM   #6
Mitch//pa
There is also a small bracket on the firewall that holds the cable
Old 08-22-2016, 07:43 PM   #7
Hook
Hook's Avatar
Had the same problem and used zip ties. I didn't know the bracket was used. Mitch/Pa, where on the firewall does the other other one go?
Thanks for the help! I learn something every day reading here.
1930 Pickup in Prior Lake, MN
Hook is offline   Reply With Quote
Old 08-22-2016, 07:57 PM   #8
Mitch//pa
I believe it's the same bracket that holds the wiring to the firewall going into the junction box on the 30-31
Old 08-22-2016, 11:17 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
A couple more pics,
Old 08-23-2016, 02:56 AM   #10
coupe1942
coupe1942's Avatar
Thanks for all the photos included in your replies, guys, as I am a visual learner, for sure.
Old 05-23-2017, 10:04 PM   #11
Tom Wesenberg
Does anyone know for sure if the bolt head is down, or is it on top?
Someone had my clip in the bottom rail lip, so I moved it to the top, where it should be. I installed the bolt from the bottom up because I couldn't fit it from the top down without lifting the body.
Old 05-23-2017, 10:36 PM   #12
Slowplane
Slowplane's Avatar
See Area 4 Speedometer cable support bracket, pg.4-14 Rev. 2011, RG&JS
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 06-27-2018, 02:33 AM   #13
Charlestrubl
You would think for a car that is almost a hundred years old, someone would get the information right and stop updating the judging standards book
Charlestrubl is offline   Reply With Quote
Old 06-28-2020, 01:38 PM   #14
swo4rd
swo4rd's Avatar
'The bolt was inserted up from the bottom up through 1929, and from the top of the frame thereafter"
Has not changed in the JSB since the second edition in 1994.
I am researching the subject of the Speedometer Cable using the search function on this site and to the point...it sucks.
swo4rd is offline   Reply With Quote
Old 06-29-2020, 08:05 PM   #15
verrece
verrece's Avatar
in a right hand drive car, does anyone know how the speedometer cable is routed?, take in mind that In the drive side there are the clutch and brake pedals
verrece is offline   Reply With Quote
Old 06-29-2020, 09:10 PM   #16
swo4rd
swo4rd's Avatar
good question
Old 06-29-2020, 09:40 PM   #17
Tom Endy
Tom Endy's Avatar
Thank you for this post. It was certainly timely. We are in the process of restoring a 1930 Tudor for my 14-year old grandson. During the past four months we have completely dismantled the Tudor. We are now in the process of putting it back together. My grandson has been much involved in the process. One of the problems we encountered was where the bracket that supported the speedo cable attached to the frame. As a senior citizen my mind was completely blank where we removed it from. My grandson and I searched the frame for the proper hole and were apparently looking in the wrong place. The responders to this post showed the exact location and it was right there in front of us. Thanks again, the bracket has been correctly installed.
Tom Endy
