10-21-2011, 07:22 AM | #1 |
B engine in a Model A for Turner
Turner, your e-mail wouldn't go through. call me 207-485-0707 Walt
10-28-2011, 08:29 PM | #2 |
Re: B engine in a Model A for Turner
Walt, Do you know of anyone who makes "rigid" rear mount for installing the B engine? I've seen the float-a-motor kits, but I would prefer a rigid mount. Thanks for the reply. Lee Turner
10-28-2011, 08:47 PM | #3 |
If your going to use the Model A trans, you'll have to cut the flywheel cover off the B oil pan and use the A bell housing. Then you can use the A rear mounts. Walt
10-31-2011, 06:47 PM | #4 |
Walt, I'm looking to use the B flywheel housing, B pan, and B trans. In your case, did you use the "float-a-motor" kit for the rear installation? I've seen that offered for the B flywheel housing. I'm looking for a rigid rear mount for the B flywheel housing. Lee
10-31-2011, 07:26 PM | #5 |
