11-15-2020, 12:24 PM | #1 |
Source for origional 53' Mercury trim clips
Who would be a good source for the original rear window trim clips, on a 1953 Mercury Convertible. I would guess the same clips would have been use on all other models to include Ford.
11-15-2020, 03:11 PM | #2 |
Re: Source for origional 53' Mercury trim clips
Don't know of any source for original clips.
First thought is how are you planning to install them if you find any? If the clip holes are accessible from inside of the trunk then your best bet would be to obtain threaded 'T' bolts, fit them to the molding as required and secure from inside with nuts. This is a tool that I have had since the 50's, made to install Ford style molding clips.
11-15-2020, 03:39 PM | #3 |
Restoration Specialties, Pa. 814-467-9842, they have a catalog of 1,000s of pictures of clips and weatherstripping, they had all the clips for my 53 ford conv, and they restored my vent windows with new rubber and window channel
11-15-2020, 04:11 PM | #4 | |
11-15-2020, 04:24 PM | #5 | |
The tool is used to expand the attaching dome to secure it after it is put in place.
11-15-2020, 05:59 PM | #6 |
11-15-2020, 06:08 PM | #7 |
Or, what I have seen done in the past, one or two #4 or#6 sheet metal screws.
11-15-2020, 08:10 PM | #8 |
The only issue, is that the screws would go directly into the top material behind the body. The reason I am replacing the old ones, is that they were incorrect and I am having a new Stayfast top put on tomorrow.
11-15-2020, 11:48 PM | #9 | |
Or use 'pop' rivets. A piece of sheet metal between the the metal seam and cloth top can be used for protection when drilling or tapping.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 11-15-2020 at 11:59 PM. |
